Convert stock distributor to HEI - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 1st, 05, 12:26 PM Thread Starter
Question Convert stock distributor to HEI
Before I try to breath some life into my 68's stock 327 2bbl, I'de like to convert it over to electronic ignition, but keep the stock appearance.
I notice the little access door on the front of the dist cap is missing, so I figure now is as good of a time as any to do it.
I do have an accell distributor that is the smaller diameter (so I don't have to modify the firewall), but not sure what to do for the coil. I don't want to use the Accell super coil I have from a previous engine.
I'de appreciate any ideas as I'm not as familiar with ignition setups as I'de like to be.
68 Camaro Roller | 68 Camaro (#matching) | 69 Camaro
KWIK 69 is offline
post #2 of 7 (permalink) Old Nov 1st, 05, 02:01 PM
Re: Convert stock distributor to HEI
I always did like the stock location on the manifold with a stock demension aftermarket type coil painted to apear stock. Pertronix makes a decent conversion for your stock dist. They have coils to match with it also. I have had decent results with them.
Just my 2 cents.
TexasPerfProd is offline
post #3 of 7 (permalink) Old Nov 1st, 05, 03:10 PM
Matt Jones
I converted my points distributor to a HEI using a duraspark pickup and the HEI module mounted on the outside, much like Dave Ray does with his. Has been working extremely well and very reliable so far.
By the way, you don't always need to modify the firewall to get a HEI to fit. I didn't.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #4 of 7 (permalink) Old Nov 1st, 05, 03:31 PM
Chad
67 Plum's Avatar
I have been using the Pertronix module and their Flame thrower coil for 3 yrs. no problems so far.
67 Plum is offline
post #5 of 7 (permalink) Old Nov 1st, 05, 04:01 PM
I kept my stock distributor and changed to pointless ignition and changed the stock distributor to a 40,000 volt unit. This maintains a stock appearance and improved performance significantly over stock distributor. If you're interested, I can give you more details. Send me a note.
'69 Glacier Blue X-55 original drivetrain Convertible
'Awesome 67 Chevelle, '69 C-10 Truck, and my new addition to the family - '67 Corvette'
GlacierCamaro is offline
post #6 of 7 (permalink) Old Nov 1st, 05, 05:17 PM
Glacier,
You have a PM
klingrr is offline
post #7 of 7 (permalink) Old Nov 1st, 05, 09:11 PM
Talking Re: Convert stock distributor to HEI
http://www.davessmallbodyheis.com
TJS69 is offline
centerforce clutch + stock flywheel Neals69SS Transmission & Driveline 15 Mar 11th, 04 02:36 AM
stock speedo conversion to electric? animal Electrical & Wiring 1 Jan 6th, 04 01:54 AM
Looking for Stock HEI weight Bushings.. Badcaiman Tech 2002 5 Jul 18th, 02 08:30 PM
HEI vs POINTS Distributor - Part II ssdanny69 Tech 2000 4 Feb 2nd, 01 07:35 AM
small body hei mike brown Tech 2000 13 Jun 13th, 00 02:20 PM
