400+ cubic inch small block help - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 1st, 05, 07:03 PM Thread Starter
MStennes's Avatar
Question 400+ cubic inch small block help
Ok I'm back I have been working every angle on my new small block and I want to know how much stroke I can go on this monster before I have start getting new things like oil pans etc? On my present 350 I have bough a CV Products road race pan and want to use it again but I dont hink it will work with a 4" stroke will it? It has a built in baffle so I would kinda like to go for as far as I can?
Thanks,
69 RS/SS vert tourer, LS7, T56, Baer, Hydrooost, GW, etc, etc,
Welfare is completely against freedom and the principles of american life, paying people not to work by stealing from the people who do is insanity.
MStennes is offline
post #2 of 4 (permalink) Old Nov 1st, 05, 08:14 PM
Harley D
HarleyD67's Avatar
Re: 400+ cubic inch small block help
What block are you using? What rods? If you want to run 4" or 4.125 stroke your best bet for the money is Milodons stroker pan. It clears most H-beam rods up to 4.125" stoke. Moroso makes one too but not as much clearance. Of course you could go all out with a fabricated pan fron Canfield , Cannon, ect.. I was in the same boat Moroso Street/Strip pan windage tray fitted crank scraper, trap doors, baffles the works. All with very low miles. If you just want big inches look into big bore with 3.75" stroke crank then you can keep your pan.
HarleyD67 is offline
post #3 of 4 (permalink) Old Nov 1st, 05, 10:01 PM Thread Starter
MStennes's Avatar
Whats the cubic inches with a 3.75? I was looking to go 427. What I want is 100% reliabilty lots of torque and about 550 or so horsepower.
MStennes is offline
post #4 of 4 (permalink) Old Nov 2nd, 05, 12:07 AM
Harley D
HarleyD67's Avatar
Your in the same boat I was a year ago. I shopped around for about 6-8 months before I decided what I was going to buy. I wanted a good value, dependability, bullet proof bottom end, @ 550hp and 530ft lbs. There are lots of ways to go. Shafiroff has a great package with there ultra street. stay with the standard specs though I had them price a 427 instead of the 434 and the price went up @ $800. Summit and Jegs have the World Motown 415 and 427 good crate motors. I was set on building up my own engine the way I wanted with AFR 210 race heads and lunatie Voodoo cam with 1.6 rockers for max lift without too long of a duration. idles quite but sound like a healthy big block when I hit the gas. So I got my bottom end from Ohio Crankshaft. Great guys good tech info, very helpful, fast turnaround, and they built to my specs. for less than most other places. Her are some sites to help you out.
www.ohiocrank.com
www.shafiroff.com
www.worldcastings.com
www.speedomotive.com
www.theengineshop.com
Hope this helps any thing else let me know
built 400 Small Block worthamterrence Engine 1 Aug 22nd, 05 02:00 PM
5.7 rods on a 400 small block French 67 Engine 9 Feb 16th, 04 02:44 AM
400 small block Murdock Tech 2000 10 Jun 12th, 01 05:08 PM
400 small block going into my car CamaroZ28man Tech 2000 4 May 29th, 01 01:12 PM
400 small block CamaroZ28man Tech 2000 7 Jan 30th, 01 01:18 PM
