383 stroker - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 2nd, 05, 11:26 AM Thread Starter
Question 383 stroker
i have a 96' camaro ss lt1 and i want to 383 stroke it. is there any major mods i will have to do, or is it basically take the stock parts out and put the new ones in?
Ride13 is offline
post #2 of 4 (permalink) Old Nov 2nd, 05, 11:50 AM
Banned
Re: 383 stroker
You may have to clearance the bottom of the cylinders and run a small base circle cam as we just dynoed a 383 two weeks ago for a customer.
Check out this link as it will give you some idea what we did.
http://www.chevelles.com/forums/showthread.php?t=106715
CNC BLOCKS N/E is offline
post #3 of 4 (permalink) Old Nov 2nd, 05, 01:20 PM
BonzoHansen's Avatar
Re: 383 stroker
Please don't post the same thread in multiple forums.
TC Member #13
BonzoHansen is offline
post #4 of 4 (permalink) Old Nov 2nd, 05, 01:59 PM
Re: 383 stroker
There's a lot to be done. For starters, you'll need to bore the cylinders .30 over. The other relatively major issue is you're computer. You'll need an edit program. Trans and rear end won't hold up to a stroker either so you'll need to go through them as well.
Quite a few guys at z28 dot com have done it. This site is more for the 1st gens. Good luck!
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
383 stroker runs like crap mwgrantny Troubleshooting 14 Oct 26th, 05 06:38 PM
383 stroker Living_Lengend Engine 3 Oct 26th, 05 01:18 PM
383 stroker??? Prostreetcamaro1 Performance 18 Oct 26th, 05 07:31 AM
383 stroker vs. 350 no69x-44 Engine 3 Mar 26th, 04 06:11 PM
383 stroker or not? Dual or single pattern cam? charlesc Performance 6 Apr 28th, 00 10:33 PM
