What is this engine from?????? - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 2nd, 05, 03:42 PM Thread Starter
Hello,
I'm going to rebuild the engine in my camaro but first I need to figure out
what it is from and what it is. I was told when I picked up the car it was a 327 but we all know you can never take the word of somebody selling a car. But I'm having a little trouble deciphering the numbers. Here is what I have so far. The casting number is 3970010 which could be a 327, but could also be a 302 or a 350. On the pad in front of the cylinder head, it has a couple sets of numbers. first it has C71103749 then it has K 08 26 a large space then either a number 1, a capitol i or a lower case L, another space and then YZ . Underneath that it has a faint stamp that says 327 but it is more vague and looks like it may have been added later. I don't understand what the l stands for and I couldn't locate the suffix YZ. Can anyone help? Thanks.
BT69chevy is offline
post #2 of 6 (permalink) Old Nov 2nd, 05, 04:10 PM
Re: What is this engine from??????
One of the listings I found for that casting number is 327-trucks and industrial. I don't have the suffix list for trucks or industrial nor have I ever seen a YZ (except on a dirtbike). Truck codes you might find, but I wouldn't know where to begin to find industrial codes.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 6 (permalink) Old Nov 2nd, 05, 05:14 PM
I'm not sure, but I'd guess it's a 350 out of a 1977 full size car.
'67 SS/RS (RR)
'68 RS conv. (J2)
'68 Z/28 (VV)
'68 Drag Car(ZZ) 11.30 @ 118
'73 Corvette Drag Car 12.64 @ 106
Kyvox is offline
post #4 of 6 (permalink) Old Nov 2nd, 05, 05:26 PM
Royce
3970010 in most cases are 350 blocks. I have two in the garage and another one. They were/are all 350 blocks. If I remember right they were used for many years, starting in the early 70's up to about 78 (that's just from memory without looking it up). Some are 2 bolt mains and others are 4 bolt. They are good production blocks to build.
True this block was used for 327's as well. The difference is just the stroke.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #5 of 6 (permalink) Old Nov 2nd, 05, 05:57 PM
JohnZ's Avatar
It's a 350, made at McKinnon Industries (Canada), originally installed in a 1977 Chevy pickup made at the Oshawa (Ontario) assembly plant.
JohnZ
CRG
JohnZ is offline
post #6 of 6 (permalink) Old Nov 2nd, 05, 06:02 PM
Thumbs up Re: What is this engine from??????
Thanks John for coming through with what it started life as!
pdq67
Learning from revamping blower engine Tokyo Torquer Performance 11 Jan 24th, 07 01:44 PM
1991 Camaro Engine Swap (88 IROC engine) Racing_Master Engine 7 Oct 20th, 05 04:22 AM
Just started Engine, some concerns KevinW Engine 17 Jun 10th, 03 03:36 AM
Engine Swap - 305 to 350... Easy? trnnbr Engine 1 May 18th, 03 09:38 AM
New Engine Break-IN Procedure (GM crate motor) sr71bb Engine 12 Dec 19th, 00 09:35 AM
