just got my new intake in for the BBC...i want to cry - Team Camaro Tech
post #1 of 12 (permalink) Old Nov 4th, 05, 09:08 AM Thread Starter
ok i just recently bought a new water pump and holley intake for my BBC 366/427 and just recently i installed the water pump. it looks great. today i went out and cleaned the intake off so no dirt will fall down into the chambers when the old intake was removed. after i removed the old intake i realized the engine was well took care of. the inside of the engine was extremely clean. like it was just rebuilt. I proceded to fitch my new holley aluminum intake. as i started to place it onto the block i immeditly realize something was wronge. there was a gap on each side of the intake. the guy i bought the intake from said it woould fit any bbc including my 366 truck engine. well it does not.
does anybody know of where i can go buy a spacer?
or better yet does anyone know how far it needs to be spaced so i can go make one.
my current mood:
i want to be knock the hell out.
67stang is offline
post #2 of 12 (permalink) Old Nov 4th, 05, 10:33 AM
Re: just got my new intake in for the BBC...i want to cry
The guy lied manifolds either fit the tall deck truck blocks or the short deck pass blocks but not both. they make spacers but they aren't cheap and can be a pain to keep straight unless you set them up with a way to attach them to the heads with screws. Are you changing the factory tall deck manifold? if you are you must come up with a different dist to use a manifold and spacers.
oger is offline
post #3 of 12 (permalink) Old Nov 4th, 05, 11:26 AM
Smile Re: just got my new intake in for the BBC...i want to cry
I've got a set of spacers that have had some port matching work, but should work fine.These are for rectangle port heads, and have never been used. PM me for details. I'd let them go really cheap. On the distributor, MSD makes one with a slip collar that is adjustable for your tall deck application. Jegs has them.
Bob Brissie is offline
post #4 of 12 (permalink) Old Nov 4th, 05, 11:45 AM
Wink Re: just got my new intake in for the BBC...i want to cry
In the long run, you probably would be better off to buy the correct intake and sell the wrong one you just bought. The guy you bought it from probably did that same thing !
TJS69 is offline
post #5 of 12 (permalink) Old Nov 4th, 05, 01:16 PM
Agreed
But I know a guy that was looking for some used spacers if you want pm me a price and I'll see if he is interested.His manifold isnt one that buying a new one would be cost effective. (He's stack injected)
TexasPerfProd is offline
post #6 of 12 (permalink) Old Nov 4th, 05, 01:51 PM Thread Starter
link to some pictures of the engine problem
67stang is offline
post #7 of 12 (permalink) Old Nov 4th, 05, 02:43 PM Thread Starter
i just added the pic Bob Brissie sent me. can anyone confirm that these rectanglar ports will work on my oval port engine?it will be helpful and great news for me to know 100% sure that they will work
67stang is offline
post #8 of 12 (permalink) Old Nov 5th, 05, 06:43 AM
Question Re: just got my new intake in for the BBC...i want to cry
Your motor is a 366/427 tall deck BB? I can't see the water pump bolt and the deck good enough to tell??
Anyway, I thought the spacers were a 1/4" thick and it just didn't look like you needed a 1/4" on each side is all??
And I think you can buy thicker port gaskets if you do some searching around that MAY just fix you right up ? Then by using silicone on each end, you may be good to go..
I'm thinking .060" and .100" or .120" thick AND maybe even thicker jobbers?
Help me out here guys as well as ask over on Team Chevelle's site b/c of all the BB guys over there too.....
pdq67
post #9 of 12 (permalink) Old Nov 5th, 05, 01:55 PM
Bill
Chris,
Just by looking at your pictures, especially the one from the front that show the passenger side head, that engine does NOT look like a tall deck block. What are the casting numbers on the back ?
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #10 of 12 (permalink) Old Nov 5th, 05, 03:12 PM Thread Starter
the casting numbers are 364779
casting cu years
364779 366T 68-90 4-bolt
t=tall deck
the water pump bolts up just like the original. lined up great to.
the intake fits good its just the two huge gaps on each side. i can shove the intake to one side against either head and all the bolt holes match up.
i'm clueless. anyhelp is welcome
67stang is offline
post #11 of 12 (permalink) Old Nov 5th, 05, 05:41 PM
JohnZ's Avatar
Weiand makes oval port intake spacers (#8206) - Jeg's has them - $140.00.
JohnZ
CRG
JohnZ is offline
post #12 of 12 (permalink) Old Nov 7th, 05, 08:05 PM
casting cu years
t=tall deck
You have a 366 Truck engine 68-90 year model 4 bolt main.
http://www.mortec.com/location.htm Here is a link for locating casting info.
BDS 502 is offline
Lobe Separation Angle questions 69ProTouring Performance 19 Oct 10th, 05 06:41 PM
Valve size info. pdq67 Engine 4 Mar 12th, 04 07:30 PM
Help with intake leak causing oil smoke 68SSConvt Troubleshooting 3 Jun 8th, 02 04:26 AM
Heat riser/crossover through the intake Sleepy-69 Engine 3 Nov 19th, 01 02:24 PM
