Locking out timing... - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 5th, 05, 09:10 AM Thread Starter
I have been thinking of locking out the timing, due to the re-curve kit I installed, and been messing with to see what the motor wants. I've tried all combos of springs and can't get to where I was with the worn out HEI parts I had. I've tried with and without vacuum advance.... what are your thoughts ?
68 Camaro~LSx ~all motor
post #2 of 2 (permalink) Old Nov 5th, 05, 09:39 AM
Re: Locking out timing...
Only in Race mode. It will work but on a street car you will benifit much more from properly working dist.
Id say scrape a little savings together and purchase a new distributor. Just my .02 cents
It may be that the wear in the shaft and other areas is preventing consistant results causing you to "chase" your problem.
TexasPerfProd is offline
SB dampener timing marks HwyStarJoe Engine 10 Aug 4th, 05 10:04 PM
getting too hot noels69 Heating & Cooling 14 May 31st, 05 08:53 PM
Vacuum advance or not??? Ethan67 Performance 55 Apr 9th, 04 06:50 PM
locking in timing at 36 degrees Conehead Performance 10 Jan 4th, 03 05:34 AM
Ignition Timing Strange Problem Mean 69 Engine 29 Apr 4th, 02 10:10 AM
