4500 dominator flange compatible with 650 holley? - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 6th, 05, 06:14 PM Thread Starter
basically what the title says. is a 4500 dominator flange compatible with a 650 holley carb. or do i need a adapter?
67stang is offline
post #2 of 8 (permalink) Old Nov 6th, 05, 06:40 PM
Bill
Re: 4500 dominator flange compatible with 650 holley?
dominator flange is larger. Better to buy the correct carb, or intake.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 8 (permalink) Old Nov 6th, 05, 06:54 PM Thread Starter
how much larger? is there enough room for me to drill and tap new holes?
67stang is offline
post #4 of 8 (permalink) Old Nov 6th, 05, 07:27 PM
Quite a bit larger. Even if you could drill and tap new holes (which I seriously doubt), the larger pad will foul most/all of the 650's linkages.
Adapter cheapest way out / Correct manifold best way out.
BlackoutSteve is offline
post #5 of 8 (permalink) Old Nov 7th, 05, 08:53 AM
Royce
I agree you would be better off with a new manifold. If you are using a 650 carb you probably do not need the manifold that accepts a Dominator. Yes, an adapter would be the cheapest way out.
No way you could drill and tap, the 650 will just about fit through the opening for the Dominator.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #6 of 8 (permalink) Old Nov 12th, 05, 04:39 PM
wes
They make a Dominator "looking" carb that is a 750 but I think its kinda high if you like that look.
wes is offline
post #7 of 8 (permalink) Old Nov 12th, 05, 07:57 PM
The 750 Dominator is a real 4500 Dominator.. That's why it looks like one!
post #8 of 8 (permalink) Old Nov 13th, 05, 06:39 AM
Gary
I can't imagine something like a super victor with a 650 on it. With a plenum that big, I can't see how signal at the carb could be remotely close to what you need UNLESS you're running a pair on something like a tunnel ram. Get a victor jr or dual plane with 4150 flange and you and your engine will be a lot happier.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
holley 650 hp flyers69 Performance 1 Sep 7th, 05 08:18 PM
What parts needed to go from Holley 650 to Quadrajet lucky13 Engine 2 Aug 22nd, 05 04:13 PM
Any chance a 650 CFM Holley spreadbore will feed my big block?? Eric Kammerer Performance 9 Aug 5th, 05 08:45 PM
Demon carb issues. Tracy Focht Troubleshooting 25 Jan 1st, 03 03:03 PM
