Oil temp gauge probe - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 8th, 05, 10:17 AM Thread Starter
Hi all, anyone ever use the oil plug drain hole to install the probe for a manual oil temp gauge on a stock pan without adding a seperate bung? Autometer is the brand. The only problem I can see may be an interference issue with the oil pickup tube. Thanks in advance & God Bless, Terry
'69 Fathom Green Coupe 350 is offline
post #2 of 6 (permalink) Old Nov 8th, 05, 12:06 PM
Re: Oil temp gauge probe
I don't see how the probe will seal in the pan plug's hole.
I'm sure the thread is different and the probe uses an internal flare to compress against for sealing.
Even the adaptor uses a 1/2" NPT which is way too big.
I think you're gonna have to remove the pan and braze the correct bung.
BlackoutSteve is offline
post #3 of 6 (permalink) Old Nov 8th, 05, 05:15 PM
JohnZ's Avatar
AutoMeter makes a special drain plug that's already drilled and tapped for their small-diameter oil temp probe; it has a removable connector on the wire that snaps (with a boot) onto the pin terminal on the probe. I used one on the 383 I built for my tube-frame Grand Sport replica, and used another one in the diff plug to keep tabs on the diff temp.
The engine oil temp and diff lube temp gauges are in the center dash console, above the switches for the fuel pump and diff lube pump.
JohnZ
CRG
JohnZ is offline
post #4 of 6 (permalink) Old Nov 8th, 05, 05:17 PM
got any more pics o that, John? Looks like an awesome ride!
post #5 of 6 (permalink) Old Nov 8th, 05, 05:43 PM
JohnZ's Avatar
Yup, here's the car and an underhood shot (weighed 2340# wet):
JohnZ
CRG
JohnZ is offline
post #6 of 6 (permalink) Old Nov 8th, 05, 08:41 PM
Ken
John ; Do you happen to know the part# for that autometer drainplug that is drilled and tapped for the small sending unit? I can't find it anywhere. Maybe you could remember where you bought it ,may help me for the search of this part. Sounds like just the ticket for easy install on oil temp guage! Thanks,
Ken.
1968 camaro,405cid,10:1comp..,#509 casting,studded 2 bolt,195raceported heads,750holley vac.sec.,cc xr300hr cam with rev kit,rpm airgap,msd dist. 6al ign.,8.5 10bolt,3.73gear,3500 stall,turbo 350 trans, 60ft-1.487,1/4-11.36,mph 116.34
NotFastEnough68maro is offline
console oil press gauge leaks BAMiller Interiors 13 Aug 18th, 05 07:00 PM
Autogauge "Smoke" Water temp gauge Martin_Nissen Electrical & Wiring 0 Jul 25th, 05 03:41 AM
Do I need to bleed the oil pressure gauge oil line? ggkeller Restoration Corner 3 Jun 10th, 05 05:20 PM
Adapter to make temp gauge work in vortec heads! wildkatz Engine 7 Apr 28th, 02 04:24 PM
