Hard Engine Bolts LE - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 9th, 05, 11:53 AM Thread Starter
I have some bolts ,that are 2 1/8 inches long,threads half way. They have the letters L E on the top. a couple of them have rockford on them.I know they are original but don,t know what part of the motor they go to. Any help appreciated. Thanks
68 SS matching
Flynn69 is offline
post #2 of 7 (permalink) Old Nov 9th, 05, 12:04 PM
Re: Hard Engine Bolts LE
Diameter? UNC or UNF? Head style? (hex only or integral washer or..) Hex size? Small block?
Are you measuring under the head or including it?
BlackoutSteve is offline
post #3 of 7 (permalink) Old Nov 9th, 05, 12:06 PM Thread Starter
I,m including the head when measuring.
Flynn69 is offline
post #4 of 7 (permalink) Old Nov 9th, 05, 12:09 PM Thread Starter
The head has 6 sides to it , 1/2 inch wide.the length under the head is 1 15/16ths.
Flynn69 is offline
post #5 of 7 (permalink) Old Nov 9th, 05, 01:41 PM
Wes
Those are both bolt brands sold at hardware stores,..not original.
How many are there? Maybe the water pump? Intake?
Straight-line-69 is offline
post #6 of 7 (permalink) Old Nov 9th, 05, 01:54 PM Thread Starter
Thanks for the info.........11 bolts....
Flynn69 is offline
post #7 of 7 (permalink) Old Nov 9th, 05, 09:49 PM
Hey Errol, I need more info please (see above), or even better would be a pic if you can..
WHY KEEP ENGINE RPMS under 7000rpm grumpyvette Performance 50 Oct 4th, 05 10:39 AM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 02:45 AM
Adjustment to fender? Winch Body Shop 4 Mar 10th, 02 02:46 PM
How long are the bolts for an engine stand? tl757 Engine 12 Nov 12th, 01 11:14 AM
Engine Stumble with Hard Brake Application memcgraw Brakes, Suspension & Steering 8 Sep 12th, 01 12:55 AM
