timing cover 302 - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 9th, 05, 04:25 PM Thread Starter
timing cover 302
is the only difference with a mr gasket timing cover and a factory cover for a 302 just the stamping of the #s.
biil9 is offline
post #2 of 6 (permalink) Old Nov 9th, 05, 04:40 PM
Dr. Feelgood
Re: timing cover 302
Could be,if it's just a mild-steel factory type.Just make sure the Mr. Gasket one has the timing pointer in the right place to accomodate the 8" balancer.
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
post #3 of 6 (permalink) Old Nov 9th, 05, 06:12 PM
Turd Fergeson
ZZMike's Avatar
It will also make a differnce if it is a '67 or '68 302, since the timing mark on the balancer is in a different location than the '69 302 engine.
1968 British Racing Green Crossram Camaro Z/28
Double Trouble
2016 Black Corvette Z06/Z07
ZZMike is offline
post #4 of 6 (permalink) Old Nov 9th, 05, 07:08 PM Thread Starter
thank you
biil9 is offline
post #5 of 6 (permalink) Old Nov 9th, 05, 07:09 PM Thread Starter
it's a 69.
biil9 is offline
post #6 of 6 (permalink) Old Nov 9th, 05, 07:12 PM
Turd Fergeson
ZZMike's Avatar
Then you should have no problems with the Mr. Gasket piece, as long as it is for the 8" balancer as previously mentioned.
Double Trouble
ZZMike is offline
DZ 302 Timing Problem Bill G Engine 13 Sep 8th, 05 02:56 PM
Timing chain cover question john68conv Engine 6 Apr 19th, 05 03:24 PM
Mismatched timing cover and balancer travis Engine 7 Apr 22nd, 04 09:25 AM
Oil leak from two piece timing chain cover? Eric68 Performance 3 Jun 30th, 03 06:49 AM
Cloyes Timing Chain Cover Tski Performance 1 Jun 17th, 03 01:38 AM
