Hedman header gaskets ? - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 9th, 05, 10:33 PM Thread Starter
HI just brought some hedman headers 2 inch primary .going onto a alloy head zz454 should i put the hedman gaskets that come with the headers on dry or use some sort of exhaust gasket sealer or throw them away and use some thing better
I hate blown header gaskets what do u guys use that works well on your headers thanks
victtor is offline
post #2 of 2 (permalink) Old Nov 10th, 05, 07:26 AM
Re: Hedman header gaskets ?
i have read on here that you should soak paper gaskets in water (i forget how long) before assembly.if the flanges are straight and you remember to retorque several times,they should be ok.
but since you sound like you hate exhaust leaks as much as i do,there are some new technologies on the market lately.dead soft aluminum header and collector gaskets from mr. gasket look real promising,as do the split lock header and collector bolts,kind of like a poly lock for your headers!anyone currently using either of these?
Eric B
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
What kind of header gaskets are you guys using for your AFR 210's? racerdoc Performance 1 Sep 18th, 05 10:29 PM
Protopline and header gaskets... DOUG G Engine 7 Apr 8th, 05 06:07 AM
So I went to the parts store today for header gaskets... travis Bench Racing 11 Feb 21st, 05 11:59 AM
header gaskets and bolts jks67SS396 Engine 2 Jun 20th, 03 10:06 AM
Header Gaskets ColoradoZ28 Tech 2000 8 May 30th, 00 06:02 AM
