Small block to Big Block converstion on a 68 - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 9th, 05, 11:57 PM Thread Starter
Hi folks, I am doing a BB conversion on my non original 307 small block 3 speed convert. I want to do a mild 396 backed with a muncie M20 that I already have,
Now my questions.. I am aware of the obivous parts needed, tell me if I'm missing anything..
BB radiator & shroud
BB clutch bellcrank
BB motor mounts
BB 4 speed X-member
BB heater box and heater core
BB exhaust headers
Misc pulleys and brackets
Oh and Disk Brakes..
Can anyone think of anything I may be missing?
Jeff
JEFFMB is offline
post #2 of 4 (permalink) Old Nov 10th, 05, 06:50 AM
Re: Small block to Big Block converstion on a 68
If you are breaking down the front end to put on discs, might as well plan on big block coil springs. If you do a search for "big block coil" you'll see what we're using.
Eric
Eric Kammerer is offline
post #3 of 4 (permalink) Old Nov 10th, 05, 08:33 AM
Talking Re: Small block to Big Block converstion on a 68
Motor Mounts AND Frame mounts.
TJS69 is offline
post #4 of 4 (permalink) Old Nov 10th, 05, 11:12 AM
Wes
1) Can't remember,..if your 307 car has a 5/16 fuel line, you'll need to up it 3/8's
2) Coil springs
3) Center Link...BB's had a larger center-link for a reason,..better safe than sorry
4) Sub-frame connectors,..mandatory or you'll twist the body
5) Beefier rear,..your 10-bolt WILL break with a BB and 4-Speed if you plan to use the available HP
6) If you don't already have a 396 engine or block, go to a 454,..more are available, and the 60 extra cubes will mean more HP with less effort (and expense)
Good luck!
Straight-line-69 is offline
New small block ideas?? MStennes Performance 54 Sep 17th, 05 06:50 AM
427 corvette engine P0RCH Engine 2 Aug 29th, 05 10:22 AM
Want to build a 434 small block DRJDVM Engine 10 Jul 20th, 04 05:26 PM
BB frame mounts further forward than small block camcojb Engine 24 Jun 28th, 03 10:23 AM
how can you tell a big block from a small block with a/c installed and no engine Devor Engine 6 Dec 26th, 02 08:00 PM
