V6-v8 Conversion Am I Able To Still Use Old 5 Speed Transmision - Team Camaro Tech
post #1 of 9 (permalink) Old Nov 11th, 05, 10:25 AM Thread Starter
JUST PURCHASED A BEAUTIFULL WHITE 88 CAMARO RS FOR ONLY 300.00 !!
BODY AND INTERIOR IN MINT CONDITION ENGINE NOT SO GREAT CURRENTLY HAS 2.8 L V-6 WITH A 5 SPEED MANUAL TRANNY IF I WAS TO DROP A V8 IN TO HER COULD I STILL USE THE SAME TRANNY ? PLEASE HELP
MilkMan is offline
post #2 of 9 (permalink) Old Nov 11th, 05, 01:55 PM
Send a message via AIM to 1FASTZ Send a message via Yahoo to 1FASTZ
Re: V6-v8 Conversion Am I Able To Still Use Old 5 Speed Transmision
I think you can use the same tranny but if you put in a high performance 350, 383, or 400 SBC, it won't last long. If you really want a 5 speed to hold up behind a strong V8, you might want to take a look at the Tremec TKO for starters but they are not exactly cheap either so it really depends on what V8 you plan to install, how you plan to use the car, and what your budget is to beef it up.
Marty Lake
1969 Z/28 fathom green X77
1FASTZ is offline
post #3 of 9 (permalink) Old Nov 11th, 05, 02:20 PM
Christropher
Fix that sticky capslock key, I can't even make it all the way through your question. It hurts my eyes. I did however read the topic and 1FASTZ's response and second his opinion. Questions need to be answered first.
Christropher
...in pieces still.
clwilcox33 is offline
post #4 of 9 (permalink) Old Nov 11th, 05, 03:03 PM
Thumbs up Re: V6-v8 Conversion Am I Able To Still Use Old 5 Speed Transmision
Fwiw, caps locked is called shouting.
And I third the light duty tranny behind a healthy 350 motor UNLESS you want to drop in a stock 220hp, 4-barrel 283 "powerpack" motor. Then, it should be fine, imho...
AND I am here ta say that a stock 283 pp motor runs darn good for JUST 283 inches!!!
pdq67
post #5 of 9 (permalink) Old Nov 11th, 05, 04:28 PM
In answer to your question, the 2.8L T-5 transmission and the V8 (305) T-5 transmissions are different animals because of input shaft length. That said, one can either swap the input shaft (HUGE pita, you don't want to do this if you have no tranny experience) or find another T5 (V8 version); chances are it'll be broken because has been mentioned before they break really easily (if you want to keep it manual and low buck I suppose you could swap in a Saginaw 4-speed (or even 3 speed) but the easiest swap would probably be a TH350 and a different length driveshaft...
From a drivability standpoint a 700r4 would also be a good choice (better gas milage) but more complicated.
Me? I'd probably find a rwd 3.1L (same engine family) and make it run a bit better while minimizing problems...then sell it for a V8 car...
radial72 is offline
post #6 of 9 (permalink) Old Nov 11th, 05, 07:17 PM
Like I said, a 305HO 5-speed behind a now solid cammed Powerpack 220hp/283 motor and go have more fun then the Law will allow!!
Install an old stock, -097 Duntov or a modern CC 270 solid or Isky Z-20 AND run her high AND hard!!
I don't know about the Isky Z-20, but the little Duntov will go above 7,000 rpm EASY!! With no more then a cheap, $25 to $35/set of Z-, (-142), valve springs!!
pdq67
post #7 of 9 (permalink) Old Nov 11th, 05, 09:29 PM
Yeah but he's got SMOG in CA...In an '88 that'd be a nightmare to pass.
radial72 is offline
post #8 of 9 (permalink) Old Nov 12th, 05, 04:54 AM
Also bellhousings are not the same bolt pattern.
68 Camaro~LSx ~all motor
post #9 of 9 (permalink) Old Nov 12th, 05, 03:20 PM
Red face Re: V6-v8 Conversion Am I Able To Still Use Old 5 Speed Transmision
Wow, my bad..
Sorry, I'm stuck waaay in the past...
pdq67
stall speed tech mmcillece Performance 0 May 15th, 05 09:35 PM
Six Speed conversion Timbo_1969 Engine 1 Jun 15th, 03 05:00 PM
Automatic to 4 speed conversion silverbbbb Engine 7 Mar 13th, 02 08:35 AM
4 speed to 5 speed conversion DanBnis Engine 41 Feb 14th, 02 04:24 PM
4 Speed to auto conversion Midlife Cruiser Tech 2002 6 Feb 10th, 02 06:12 AM
