Need advice wiped cam lobe in new engine - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 11th, 05, 08:24 PM Thread Starter
Chad
67 Plum's Avatar
Put engine in yesterday fired it up this morning ran it for 20 min. between 2000 and 3000 rpms.Idled it down set timing and carb.Took it down the road for a spin everything was fine.Drove it for about 10 miles this afternoon and valve started ticking.Pulled the valve cover and number 7 intake was loose.Checked lift at pushrod and it was .100 low.Pulled intake and the lifter and lobe are worn down.Its a Crane 274H06 hyd cam.Used their assembly lube and everything was clean.Now for the question should I pull the engine and go back through it or just replace the cam?
67 Plum is offline
post #2 of 6 (permalink) Old Nov 11th, 05, 09:29 PM
Re: Need advice wiped cam lobe in new engine
Pull it and go back thru it because all that metal is now in the side of the piston skirts.
Rogers Performance is offline
post #3 of 6 (permalink) Old Nov 12th, 05, 02:58 AM
Wes
Agree,..too much shrapnel floatin' around,..need to pull her out, inspect, and fix the damage, which could be anywhere that uses down-flow (gravity) for lubrication (up-flow is filtered,..crank and bearings for instance, will be ok).
When installing lifters next time, make sure every one would spin freely in it's bore. If one doesn't, you'll wipe a lobe. This condition is aggravated by lobes that are too steep (in my miniature opinion),..i.e., the Comp Cams XE line.
Straight-line-69 is offline
post #4 of 6 (permalink) Old Nov 12th, 05, 12:15 PM
Patrick
67Plum: I had the same thing happen to me with an eldebrock cam. Unfortunately I had to learn the hard way that I should have torn the whole engine down and cleaned everything. I just replaced the cam and lifters, changed the oil and drove it, it only lasted about 3000 mi. then the oil pressure started to fall drastically. When I finally decided to tear the motor down, every bearing was worn out. I had to rebuild the whole engine again. Be shure you get the engine hot tanked and take the cam bearings out because metal particles will be trapped behind them. I cannot stress how important it is to clean every part thoroughly before assembly. Hope all goes well!
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #5 of 6 (permalink) Old Nov 12th, 05, 01:09 PM
Darn, Plum, that's just a beech!
post #6 of 6 (permalink) Old Nov 12th, 05, 02:46 PM
Banned
Check this thread out and read what I have witten as this may help you out and if your oil filter bypass was pluged and you a ghad a WIX or NAPA filter on you may habe not hurt the Crank and bearings.
Hope everythng looks good
CNC BLOCKS N/E is offline
Learning from revamping blower engine Tokyo Torquer Performance 11 Jan 24th, 07 01:44 PM
Cam selection help Planet Camaro Performance 33 Jun 24th, 05 06:45 PM
engine builder's code of ethics?? / big block oil pressure ?? caribbean camaro Engine 4 Jul 9th, 03 04:05 PM
Rhodes hydraulic lifters jlighthart Engine 13 Feb 23rd, 03 03:45 PM
need advice on cam. Lukes67 Performance 11 Jan 10th, 01 12:33 PM
