need help with 82 camaro Berlinetta - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 11th, 05, 10:41 PM Thread Starter
ok-im new at this.....I just bought a 82 Camaro Berlinetta(stole it) in great shape--however it had a electronic 2-bbl throttle body on the 305 and I want to put this 4bbl manual Edelbrock on---Problem...I have ports on this new carb for hoses but cant find more than 2 hoses in the car...and im at aloss when it come to changing out this 2bbl electronic back to the 4 bbl--dont know if there's any wiring that I can use on the new carb....im stumped...HELP...PLEASE
mldofarkansas is offline
post #2 of 6 (permalink) Old Nov 12th, 05, 11:57 AM
Re: need help with 82 camaro Berlinetta
Go to the parts store and get the rubber caps you need to plug anything you aren't going to use.
deerhunter is offline
post #3 of 6 (permalink) Old Nov 12th, 05, 03:27 PM
Steven
If you got the manual ( choke ) edelbrock, then there are no electonic connections to the carb...You will have some vacuum connections. As deerhunter stated, you will need to place caps on the unused ports ... Don't be surprised if the throttle linkage requires some "fabricating" and you will probably need a drop-base air cleaner to be able to close the hood ...BTW, what kind of intake are you going to use ?
sdtsdt is offline
post #4 of 6 (permalink) Old Nov 12th, 05, 10:55 PM Thread Starter
im gonna use a "High-Rise" intake
post #5 of 6 (permalink) Old Nov 12th, 05, 10:58 PM Thread Starter
my mistake--not thinking---its a automatic choke on the edelbrock carb----got the caps too--just praying (alot) that I get it hooked up right---lol
post #6 of 6 (permalink) Old Nov 13th, 05, 09:26 AM Thread Starter
what do I hook the vac port on the distributor..to ? Distributor is a ACCEL-High Performance.........HELP
Holy Cow New CAMARO!!!!! BBC1 Bench Racing 39 Jan 10th, 06 08:15 AM
What is a 70 Camaro? Amptech Tag Team 14 Sep 29th, 05 12:08 PM
The Camaro name Trick1 Camaros.net Site Help Discussion 10 Sep 19th, 05 01:09 PM
CAMARO IS BACK IN 2007!!!!!!!!!!!!!!!!!!!!!!!!! dawg Bench Racing 32 Apr 24th, 05 08:27 PM
1984 camaro berlinetta no air/heat/fan WAD77095 Troubleshooting 1 Jul 17th, 00 05:02 AM
