427 Harmonic Dampers - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 11th, 05, 11:17 PM Thread Starter
Craig
Can I use a 454 harmonic damper on a 427 engine . I are having difficulty getting the correct one ( I live in Australia ) & most places can supply a 454 one but not a 427 . are there any differences
Craig
lazyone is offline
post #2 of 6 (permalink) Old Nov 12th, 05, 01:35 AM
Bill
Re: 427 Harmonic Dampers
NO, the 454 balancer will NOT work it is an externally balanced motor.. The 427 one you need is internally balanced motor and is a completely different motor. The good thing is you can get the balancer off of any other big block EXCEPT the 454. They should not be that hard to find.
Amptech is offline
post #3 of 6 (permalink) Old Nov 12th, 05, 02:19 AM Thread Starter
Craig
Thanks , I will try harder to find the correct one.
lazyone is offline
post #4 of 6 (permalink) Old Nov 12th, 05, 02:45 AM
Wes
I have an original GM low mileage balancer that was used with high perf 396's and 427's from 67-69. GM part number 3879623,..8" internally balanced damper.
E-mail if you're interested.
Straight-line-69 is offline
post #5 of 6 (permalink) Old Nov 12th, 05, 05:07 AM
Gary
Should be real easy getting the 427 damper where you are, they are made in your country for the aftermarket suppliers and are marketed in the U.S. Thanks, Gary in N.Y.
GOSFAST is offline
post #6 of 6 (permalink) Old Nov 12th, 05, 08:43 PM Thread Starter
Craig
thanks , will try some of the bigger performance parts guys
lazyone is offline
Harmonic vibration at 4400 RPMS Orange68 Transmission & Driveline 11 Oct 18th, 05 05:38 PM
Harmonic Dampers? MStennes Engine 6 Mar 28th, 05 07:06 AM
Harmonic Dampers Chopper Performance 7 Aug 13th, 04 09:38 AM
BIg Block Info I got off the web! Very long! pdq67 Performance 6 Jan 5th, 02 03:08 PM
liquid VS. elastometer harmonic dampers dm Tech 2000 3 Mar 26th, 01 10:24 AM
