What machine work should I have done to y block and heads? - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 12th, 05, 05:29 PM Thread Starter
Hey guys I am picking up a 454 with 781 heads tomorrow. But I need to decide what machine work I need. This is going to be kind of long, but I would rather ask now since i have never done it before than find out to late.
First of all what machine work should i have done to the block? I know I need it magnafluxed, hot tank, bored out. But I am wondering if I should use a torque plate when boring? Should I have it alined honed? Also someone told me that I should have the lifter bores cleaned up because that is a problem on big blocks. Is it worth the extra money for the aline hone and troque plate?
Is there anything else I should have done?
The heads are bare so I am going to have larger valves put in. But should i have them do a full port or do a gasket match and a little bowl work done? Or tell me what you think I should do.
I am looking to make 500-550HP. But might want a little more later so I don't know what I need done to the heads. I don't want to skimp, but don't want to spend more than I need to. This i sort of a budget build.
Any and all help is welcome.
thanks
Tom Ziokowski is offline
post #2 of 3 (permalink) Old Nov 12th, 05, 06:47 PM
Re: What machine work should I have done to y block and heads?
torque plate - Yes
alined honed - Have it checked if it needs it have it done
lifter bores - Definately check this if running a Flat Tappet cam Solid or Hyd. Roller cams solve this unless something is way out here.
Definately worth it in my opinion if your building a "Performance" based engine. If you think about this like the foundation of your new home. A budget home or a mansion will come down if the slab isnt done correctly.
I would have the deck checked just to make sure all is true and square. If it isnt have it done.
No need for a full blown port job I would have under the valves cleaned up (which you can do if you have a little time and a Dremel, Directions are on the net). Intake ports could be cleaned up to match the gaskets but at 550hp its not needed unless they are way off on the top of the ports. This is usually not the case.
TexasPerfProd is offline
post #3 of 3 (permalink) Old Nov 12th, 05, 07:54 PM
Consider the cost of what you want done to your heads. Big valves, new seats, guides, port work, springs, retainers, locks etc.. It may be only slightly dearer to buy some nice assembled aftermarket heads.
If it's a MkIV 454, I would definitely have the lifter bores checked. The tooling was never consistant on these.
BlackoutSteve is offline
Casting Dates Heads Vs Block DZ Fool Tag Team 9 Oct 22nd, 05 05:39 PM
interpret my time slips...whats happening? BBC1 Performance 60 Jul 12th, 05 09:15 AM
400 SBC COMPRESSION RATIO DTL504 Performance 37 Dec 10th, 02 08:39 PM
Big Block Heads cpodeep Engine 9 Feb 26th, 02 04:20 PM
327 heads and block bmx351 Tag Team 2 Jun 5th, 01 10:18 AM
