need help with this - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 12th, 05, 06:03 PM Thread Starter
need help with this
I am having a problem with my car running rich. I have been fighting the problem since I got it back from the body and paint (1 year 3 months). It seems like all the plugs are black except 1 & 3. It started out wet and black but when I changed my fuel pump the plugs arent wet but still black. Also the secondary air/fuel screws seem to work properly, when I turn them in the engine will shut down but I can turn the primaries in all the way and the car wont shut off. My original fuel pump was 6 psi when it was new then moved up to 7 psi thats why I changed it and it seems to make a difference but now that the plugs are dry and black I still have an issue and any advice would be appreciated. thx
1969 camaro convertible, sm blk 350 trick flow heads, m21 muncie, 3.73 rear. hugger orange with blacks stripes. 12.90 @ 107mph
flyers69 is offline
post #2 of 3 (permalink) Old Nov 13th, 05, 04:37 PM
Re: need help with this
Just from your description, it sounds like the secondary carb plates are cracked open. I'm assuming it's a Holley, since you mention 4-corner idle adjustment screws. There may be other carbs with 4-corner adjustment, so please nobody bite my head off.
Anyway, there is an adjustment screw that will allow the secondary plates to close all the way. I would start there. Your adjustment at idle should come mostly from the primary. I would check the carb manufacturer's web site and get instructions on setting the primary and secondary butterflies.
Also, an easy test would be to swap out another carb from a buddie's car; one that you know is running properly. That way, you could see if the carb is actually the problem. You could have any one (or more) of a number of other issues; vacuum leak, bad cap, rotor, wires, coil, etc, etc..........
Dave F. in Rhode Island
Chevy-SS is offline
post #3 of 3 (permalink) Old Nov 14th, 05, 06:39 AM Thread Starter
thats a good idea to swap carbs just gotta find someone willing. ill try that since it seems to be the easiest thing to do thx.
flyers69 is offline
