throttle plate swap? - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 13th, 05, 02:48 AM Thread Starter
Send a message via Yahoo to camaronut79
is it possible to swap throttle plates from a v.secondary to a dpump there both 600cfm carbs and they both look the same?
camaronut79 is offline
post #2 of 3 (permalink) Old Nov 14th, 05, 05:00 AM
Re: throttle plate swap?
Yes, you can, but the new hybrid carb will have a dead spot when opening the secondaries.
600 DP has 66 primary, 73 secondaries, Prim PV is 65, Prim discharge is .028, Sec nozzle is .032.
If you do decide to run the primary metering plate on the secondary side, sec power valve would be half, ie, 35.
post #3 of 3 (permalink) Old Nov 14th, 05, 05:25 AM
I think he's talking about the base plate.
I'm not sure if they're the same or not. Look at Holleys web site for what you have and see if they're the same part number.
68 Camaro~LSx ~all motor
Front licence plate bracket Scoop69RS-SS Body Shop 9 Jun 16th, 05 06:49 AM
Pressure plate to flywheel Tire Smoke 69 Transmission & Driveline 4 Sep 20th, 03 04:02 PM
TPI throttle sticking geo's 68 Troubleshooting 2 Jul 23rd, 03 04:28 AM
I6 swap. need help with throttle linkage john68camaro Engine 3 Feb 24th, 03 12:09 PM
Drilling holes in throttle plate Dobek Performance 5 Jul 17th, 01 11:44 AM
