Engine build help (327) - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 14th, 05, 05:17 PM Thread Starter
Right now I have a 327 in my Camaro, the motor was in the car when we got it and runs fine so I'm leaving it alone for now. Here is what I know about the engine.
'68 327 small journal block
ported and polished 2.02 1.60 heads
hydraulic lifters
B&M 144 blower
Holley 750 double pumper
I would like to replace the motor in the car with a 4 bolt 327, I know they didnt make one, but I was told I could just put a 327 crank in a 350 block? I would like to have Forged everything in the motor, and I want to tune the blower to put out about 10-11 pounds of boost. I want to keep the same heads, but what kind of lifters should I run, also should I change over from the stamped rockers to roller rockers? How will this affect driveabilty? I plan on driving the car pretty often but still take it to the track. I dont really mind the horrible gas mileage or anything, its just part of driving a high performance car . Any suggestions would be great.
BLADE4444 is offline
post #2 of 5 (permalink) Old Nov 14th, 05, 08:26 PM
Smile Re: Engine build help (327)
First off, a '68, 327 will have medium journal crank in it.
And yes, you can drop a medium journal 327 crank in a 350 4-bolt main block and there you go. Try to find a mid '70's/'80's P/U 4-bolt main block... There should be a million of them out there??
pdq67
PS., and fwiw, everything '67, except the '67, 350 motor on back is small journal and when '68 rolled around, they all converted to the medium journal cranks.
And the 400 is a large main journal SB..
post #3 of 5 (permalink) Old Nov 14th, 05, 09:27 PM
Thumbs up Re: Engine build help (327)
You can make your block either a 4-bolt with new 4-bolt caps and keep the block you have, and install 4-bolt splayed caps etc. on it. This way you can save the original block. That is if it is original to the car.
TJS69 is offline
post #4 of 5 (permalink) Old Nov 15th, 05, 04:02 AM
Banned
On the small journal block the only 4 bolt cap to put on is the splayed cap as there is not much webbing to put on a standard 4 bolt cap. We have done a lot of the splayed caps on the 327 blocks over the years as the caps make a much more reliable engine.
CNC BLOCKS N/E is offline
post #5 of 5 (permalink) Old Nov 15th, 05, 09:09 AM
Thanks Carl, for the "heads up" on the webbing. I wondered about that after posting. Is their enough material on a large journal ? (or medium as PDQ states !)
TJS69 is offline
67 camaro 327 engine. original vs. crate replacement DALEJRFAN8 Engine 12 Sep 7th, 05 11:43 PM
Engine Mounts 327 to 350 crate engine Sixty-Seven rs Engine 3 May 12th, 05 04:01 PM
ENGINE DATE AND CAR BUILD DATE robbie shirkowski Restoration Corner 4 Jan 6th, 05 09:59 AM
I want to build an engine rphtx Engine 12 Jun 28th, 03 04:02 AM
EBAY or Build Balboni Performance 16 Jun 3rd, 03 11:16 AM
