4-7 swap - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 15th, 05, 06:28 PM Thread Starter
4-7 swap
does anybody use this cam the 4 - 7 swap witch is suppose to swap the firing order of the number 4 and number 7 cylnders. i belive its a comp cam, and trying to figure out if i want to run this cam its going in a 427, so i was also woundering if it sounds different because i dont want to lose the big block rumble.
bmarshall68 is offline
post #2 of 2 (permalink) Old Nov 15th, 05, 06:32 PM
Royce
Re: 4-7 swap
Do a search on this topic it was discussed not long ago. Any cam grinder can grnd a 4-7 swap cam for you.
It is usually not worth the effort or money unless you have a VERY large cube engine.
Royce (NO XQSSS) Bradley
camaroman7d is offline
