350 to 454 conversion - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 15th, 05, 11:27 PM Thread Starter
Question 350 to 454 conversion
Hello, I am going to install a 454 into my 1969 camaro which originally came with a 350. Does anyone know what problems I could incur i.e. frame mounts, clearances, headers etc. Any help would be greatly appreciated. Thanks, Russ
rjrj4 is offline
post #2 of 3 (permalink) Old Nov 16th, 05, 06:02 AM
Re: 350 to 454 conversion
Russ -
Welcome to Team Camaro! There is a lot of info on this swap to be found searching the forums using such terms as "big block", "big block mounts", "big block springs", etc. We've helped two people with this swap in the last week, so you may even see threads just by looking at the last 10 days or so in this (engines) forum.
Do the search, and then if you still have questions, come back. My 69 is a former 6 cyl car, now with correctly mounted BB. Lots of us have done this swap.
Eric
Eric Kammerer is offline
post #3 of 3 (permalink) Old Nov 16th, 05, 06:16 AM
I did two of these swaps in the last four years. Most stuff bolts in good, but you need a few new parts:
1) big-block frame mounts (move engine 1" to pass side)
crossmember with offset holes to passenger side (or use poly trans mount and 2) use passenger side hole in crossmember to center hole in mount)
3) BB clutch bell crank (if standard trans)
4) BB radiator
5) assorted small parts like pulleys
6) BB front coil springs
I know there's more parts and someone here has probably put together a very thorough list already, so I ain't gonna try to out-do that. Do a LOT of research before you buy headers. Clearances are definitely an issue. I bought new Hooker Super Comps for my 454 into a '68 swap and had to dent three or four places to get them to fit. Man, I hated denting up a brand new set of jethot-coated $600 headers.
Bottom line: it's a easy swap and VERY rewarding the first time you mash the go-pedal to the floor.
Dave F. in Rhode Island
Chevy-SS is offline
