High Idle - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 19th, 05, 11:35 AM Thread Starter
Question High Idle
I have a 355 with a 501 lift cam 292 duration....I'm running with a 327/350hp vette intake and a holly 750 single pumper ontop headers ect ect ect....4 spd car with disk brakes....the thing is that the car will take a long time to idle down...mmmmmm....a couple of people have told me to drill a 1/8 inch hole in the carb butterfly to let a bit more air in.......mmm....any thoughts ? any ideas on what I should be looking at ? ALL parts are new on this thing...except the distributor...it has a pertronix system in it...but...could the dist cause this ?
Thanks for your help..
Johnny in AZ is offline
post #2 of 3 (permalink) Old Nov 19th, 05, 11:39 AM
Re: High Idle
I have experienced this before (more than once) and it was simply a weak throttle return spring.
Another possibility is that the secondary butterflies are not closing all the way. There is an adjustment screw located underneath the card which needs to be PERFECTLY set, in order for butterflies to close properly.
Also, could be sticking choke mechanism.
I bet a cold one that your problem is one of those three things. Of course, it could be something else, but those are my guesses.......................
Dave F. in Rhode Island
Chevy-SS is offline
post #3 of 3 (permalink) Old Nov 19th, 05, 11:40 AM Thread Starter
Re: High Idle
return spring is new and tight....I'll have a look at the adjustment on the carb..
