Engine stops when runing - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 19th, 05, 03:03 PM Thread Starter
Question Engine stops when runing
The engine just turns over for a while then it starts up, it will run for 1 min and stop. Once stopped it will not start for a bit then I start over again on then off. I have checked the pickup coil 825 ohms I have changed out the wires, plugs, rotor and cap not the ignition coil (HEI) not sure on how to trouble shoot that also replaced the module, not sure about the capacitor. The engine is a 350 out of a 74 Monte Carlo.
GeneralRaider is offline
post #2 of 3 (permalink) Old Nov 20th, 05, 05:13 PM
Wes
Re: Engine stops when runing
Sounds like a fuel delivery problem,..maybe a fuel filter?
Straight-line-69 is offline
post #3 of 3 (permalink) Old Nov 21st, 05, 02:25 PM Thread Starter
Arrow Re: Engine stops when runing
there is a apark sometimes then it goes away so its intermittent.
