cam problem - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 20th, 05, 04:14 PM Thread Starter
cam problem
my buddy has a 65 nova ss with a 327. he has edelbrock cam setup. everything is supposed to be matched. dart heads. for the second time in a short period of time he has had to pull the engine down and replace the cam. the same lobe keeps wiping out. it is the #6 piston intake. could it be the head that is bad (valve spring, bent valve)? cam bearings? or just a bad cam for the second time? it is a hydraulic camshaft. if you have any advice of what he should do first please help. thanks
1slow67maro is offline
post #2 of 2 (permalink) Old Nov 20th, 05, 05:38 PM
Re: cam problem
read this, might help: https://www.camaros.net/forums/showthread.php?t=63448
