vacuum pressure - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 21st, 05, 02:53 PM Thread Starter
vacuum pressure
i have a 91 camaro rs 305 tbi. what should my vacuum pressure be?
divinezx9 is offline
post #2 of 11 (permalink) Old Nov 21st, 05, 04:56 PM
Re: vacuum pressure
vacuum and pressure are opposites
but your vacuum should hopefully be 14" or more at idle, and steady, if it is jumpy you have a problem
400bird is offline
post #3 of 11 (permalink) Old Nov 21st, 05, 09:54 PM
"Tri-Tip"
Gary L's Avatar
Re: vacuum pressure
Sorry, have to disagree. Vacuum is negative pressure.
Gary L is offline
post #4 of 11 (permalink) Old Nov 21st, 05, 11:27 PM
Re: vacuum pressure
ya well you say tomato and i say potato
and then his pressure should be at -14"
400bird is offline
post #5 of 11 (permalink) Old Nov 22nd, 05, 04:07 AM
Re: vacuum pressure
So then, pressure is positive vacuum?
edit:
Or, would pressure be negative vacuum, due to the use of a double negative?
'67 SS/RS (RR)
'68 RS conv. (J2)
'68 Z/28 (VV)
'68 Drag Car(ZZ) 11.30 @ 118
'73 Corvette Drag Car 12.64 @ 106
Kyvox is offline
post #6 of 11 (permalink) Old Nov 22nd, 05, 08:48 AM
"Tri-Tip"
Gary L's Avatar
Re: vacuum pressure
Yup.
Gary L is offline
post #7 of 11 (permalink) Old Nov 22nd, 05, 08:48 AM
"Tri-Tip"
Gary L's Avatar
Re: vacuum pressure
edit:
LOL.
Gary L is offline
post #8 of 11 (permalink) Old Nov 22nd, 05, 09:20 AM
Re: vacuum pressure
Merriam-Webster: vacuum (noun): a degree of rarefaction below atmospheric pressure
If engine is in good mechanical order, no sticking valves, no plugged exhaust, and ignition in good order, a stock camshaft, and correct initial timing, the vacuum gauge should read at operating temperature in neutral at idle speed 15-20 in./Hg. steady.
post #9 of 11 (permalink) Old Nov 23rd, 05, 02:31 PM
"Tri-Tip"
Gary L's Avatar
Re: vacuum pressure
Unless it is a 30-30, then 9-10".
Gary L is offline
post #10 of 11 (permalink) Old Nov 23rd, 05, 02:32 PM
"Tri-Tip"
Gary L's Avatar
Re: vacuum pressure
Unless it is a "stock" 30-30, then 9-10".
Gary L is offline
post #11 of 11 (permalink) Old Nov 23rd, 05, 02:58 PM
Wink Re: vacuum pressure
I wouldn't think anybody be foolish enough to install a "stock" 30-30 camshaft in a 91 305 TBI engine.
