Engine build advice - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 23rd, 05, 12:42 PM Thread Starter
Ben
Engine build advice
I just posted this in the "performance section" as well-
Hey guy's I'm looking for a little advice on building an engine for my '67. Currently, the car has a smallblock that I know little about. Big cam, 462 casting number heads. Whole lot of bark, not a whole lot of bite. The block decodes as a 283 from 1961. I know-big time. It runs pretty well, Probably in the 250-275 hp range (the same as my Maxima-dammit). I doubt near 300. It's really a mystery of parts. OLD Offy intake, but a new Holley 750DP-which is obviously too much for the car-but it runs well. Carb was put on by the previous owner, who also did the tranny.
I want to be able to cruise with little drama with the wife and 2 kids, run on pump (premium), support A/C (which the car has), and run a high 12-low 13 quarter. A little cam lope never hurt anybody -I'm coming from the world of turbo Porsche (944) which sound like a sewing machine-even over 400hp.
Right now, the car does everything but the quarter time. So, what do I build/buy? 350, 383, 406? What hp level would be needed there? The car currently has a TH350, newly built with a 3000 stall, 3.73 rear.
I owned a 1970 Chevelle SS, which was set-up with a pretty stout 427. Big cam, huge compression, and a lot of headaches. This car will get driven to my office a couple of times a month, cruise on the weekends-and may get taken to the drags once a summer. I suppose I could leave it alone-and just never race anybody. It could pass as a 12 sec car, as long as I never race it, but what's the fun in that?
Do I keep the heads, or sell the motor as whole/running? I don't know if they are 1.94, or 2.02 heads. What would you do?
Ben Wornall
1967 Camaro Sport Coupe
BW67 is offline
post #2 of 4 (permalink) Old Nov 23rd, 05, 01:42 PM
Re: Engine build advice
HELLO BEN......I JUST RECENTELY BUILT A 383 STROKER FOR A CUSTOMER AND WE WERE QUITE IMPRESSED FOR A BUDGET ENGINE.IT WAS A 67 CAMARO RAGTOP,350 TURBO WITH NO SHIFT KIT OR CONVERTOR AND 3.08 GEARS.THE CAR RAN 13.30 ON STREET TIRES THROO THE MUFFLERS SHIFTING AT 5500RPM,THE TYPE OF MOTOR YOU COULD DRIVE ALL OVER.UNFORTUNATENTLY SOME THIEF LIKED THE CAR TOO AND IT WAS NEVER FOUND.......HERE WERE THE SPECS.........383 BOTTOM END,9.3 CR,270 COMPCAM MAGNUM,TRICKFLOW OUT OF THE BOX HEADS,TORKER AND 650 DP HOLLEY...........VISIT US AT www.hardcoreparts.ca
pro1 is offline
post #3 of 4 (permalink) Old Nov 24th, 05, 10:25 AM
Well, your choices are limited only by your budget. But you have set a few parameters which limit some choices. You're looking for a driver, so that rules out tunnel rams and wild cams. So you basically want a strong, streetable engine with gobs of power. Hmmmm, that sounds like the same objectives as about 99% of us, LOL.
Personally, I'm a huge fan of the old adage, "there's no replacement for displacement". I guess that means I'd build a moderate (read: driveable) 406 rather than a wild 350. All things being equal, more displacement will virtually always give you more torque. More torque equals more low-end acceleration, which is what works on the street and makes the car fun to drive.
Lots of different opinions on this subject, for sure. But my vote is: go big on displacement but keep it reasonable as far as cam selection, carb, etc.
Just my $.02
good luck......................
Dave F. in Rhode Island
Chevy-SS is offline
post #4 of 4 (permalink) Old Nov 25th, 05, 08:28 AM
BW67, I'll send you a PM...I think I have just what you need. BTW, I work in Gardner, Ks and live (part time) in Spring Hill, Ks...probably less than 20 miles from you.
travis is offline
