Holley 4150HP question - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 26th, 05, 01:59 PM Thread Starter
I purchased a 4150HP Holley 950 double pumper and there are no vacuum ports. Is this correct? Do you go without vacuum advance or hook up elsewhere?
69StrokerSS is offline
post #2 of 3 (permalink) Old Nov 26th, 05, 02:32 PM
Re: Holley 4150HP question
These Are Race Oriented Carbs,the Reason You Wont Have Vacuum Ports....downlegged Boosters/no Choke Horn Designed More For Racing Almost Impractable For Street Use.also Its Alot Of Cfm For Street Use Unless You Have A Big Inch Engine. If Your Running A Mild Street Engine It Is Better With Vacuum Advance Distributor And Smaller Cfm.
pro1 is offline
post #3 of 3 (permalink) Old Nov 26th, 05, 02:49 PM
Just drill & tap a 1/8"npt hole into the manifold behind the carb base and fit a barb for the advance.
BlackoutSteve is offline
