oil color - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 26th, 05, 07:31 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
oil color
After break-in ,the first oil (Delo 15-40 with EOS and assembly lube) came out dark. I changed the oil one other time to go from Valv 10-40 to Valv 10-30. The 10-30 I just drained after re-installing the heads was very dark also. Only 200 miles on the engine. Is the dark oil normal saying the engine needs more break-in or what? Do combustion gases make the oil dark?
Gary L is offline
post #2 of 3 (permalink) Old Nov 26th, 05, 08:39 PM
Smile Re: oil color
Gary,
I don't think you have enough miles on it to even begin to tell..
I used EOS, Moly Lube and 30wt to break mine in as well as I retorqued my heads after a days commute three times and then change my oil at say after a week or up to 500 miles!!
Then daily drove her until about 3000 miles and then changed again to see how my oil was doing..
pdq67
PS., I did dip-stick her every morning tho!!
post #3 of 3 (permalink) Old Nov 28th, 05, 06:23 PM
JohnZ's Avatar
Re: oil color
Yes, they do - that's what detergent oils do - they hold contaminants in suspension; I wouldn't worry about it.
JohnZ
CRG
JohnZ is offline
