What Next? - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 28th, 05, 08:50 PM Thread Starter
What Next?
ENGINE:
350 4bolt main .030 over
882 Cast Heads
~9:1 compression
272 Crane Cam
650 CFM Double Pump Holley
Performer RPM Manifold
Roller Rockers
DRIVETRAIN:
M22
12-bolt 3.73 Posi
When I built the motor in '94 I had to worry about CA SMOG requirements. Now I no longer need to worry. I was thinking about CAM and HEADS, where should I go from here? I remember 9:1 compression, but don't remember which pistons I put in the motor. Allthough 10 years old, the shortblock only has about 15k on it.
Suggestions appreciated.
eville is offline
post #2 of 10 (permalink) Old Nov 28th, 05, 09:15 PM
Re: What Next?
you got it, cam and heads, 'specially heads.
post #3 of 10 (permalink) Old Nov 29th, 05, 02:18 AM
Re: What Next?
http://www.edelbrock.com/automotive_...age_main.shtml
POWER PACKAGE
The Edelbrock Total Power PackageŽ System...
Proven Performance With No Guesswork
To get great performance out of any engine, the components must work together. Since the early 1980s, the Edelbrock Total Power Package System has solved the parts matching puzzle for many street performance enthusiasts. Intake manifolds, camshaft kits, cylinder heads and carburetors are the core of the Power Package. In 2005, Edelbrock is adding even more choices in components to get even greater performance gains out of an engine. The original "no guesswork" package now includes more manifolds, more cam kits and more cylinder heads. Street legal Power Packages are possible with the emission legal square-bore carbs. Our street legal Tubular Exhaust System headers (TES) or Shorty Headers, SDT Series Mufflers and Cat-Back Systems complete the Edelbrock Total Power Package in late-model, emission-equipped vehicles.
In order to view the "Power Package Concept" you will need Acrobat ReaderŽ. If you do not have this installed you can download it here (right).
This Power Package Concept are in PDF format in order to allow for the best possible viewing due to the layout and complexities of this particular section.
Power Package Concept (225k)
Performer Power Packages - Idle to 5500 RPM (221k)
Performer RPM Power Package - 1500-6500 RPM (600k)
Ethelkilledfred is offline
post #4 of 10 (permalink) Old Dec 1st, 05, 09:50 AM
Re: What Next?
Ditch those heads quick! The 882's are crack prone, and flow pretty poorly. A good budget way to bump up the power would be to throw on a set of GM Vortec heads. The only downfall is that you'll need to get a new intake that is compatible with the Vortec heads. You'll also need centerbolt valvecovers. But for the price of the heads, you can't beat 'em. Plus, you can always recoup your costs of the new stuff by throwing your old heads and intake on eBay...
jasonty is offline
post #5 of 10 (permalink) Old Dec 1st, 05, 12:26 PM
Re: What Next?
Depends on what your trying to do with it.. Make gobs of power?? Ditch the whole motor and stuff in a big block. But otherwise, yes, start with the heads and cam.. blower??? maybe ???
Long Gone: 1984 Z28, 1989 RS
Current : 1967 Coupe w/350, 2010 2SS
My Photobucket >>
dragon0123 is offline
post #6 of 10 (permalink) Old Dec 1st, 05, 12:51 PM Thread Starter
Re: What Next?
Any other recommendations on heads/cam? I'm not thinking BB for this car and pref. naturally aspirated. Would like to keep very streetable maybe get this thing towards 400HP.
eville is offline
post #7 of 10 (permalink) Old Dec 1st, 05, 01:10 PM
Re: What Next?
Any number of aftermarket heads will get you there, or close.
Before you buy any, you need to verify your pistons... so you know where the CR will fall. If you have flat tops, a 64cc head will put you close to 10:1, right where you need to be for pump gas.
Dart iron Eagles are great at a great price. If you want alluminum there's lots of choices, edelbrock, AFR, brodix to just name a couple.
post #8 of 10 (permalink) Old Dec 1st, 05, 01:23 PM
Re: What Next?
Ditto on heads & cam. If it were me, I would try to get better heads first and then see how your combo runs with the cam you already have. Just my .02
Granny's 69 is offline
post #9 of 10 (permalink) Old Dec 1st, 05, 02:56 PM Thread Starter
Re: What Next?
Short of tearing apart the motor, is there any way I can evaluate the pistons? Measure current compression?? Just wondering...
thanks.
eville is offline
post #10 of 10 (permalink) Old Dec 1st, 05, 03:42 PM
Re: What Next?
Any way you can remeber what pistons you put into it. Ive got the same heads on my camaro. Ive got the cc's written down somewhere on them.. Otherwise your going to have to take the heads off to determine I think.. I dont think a compression test would be accurate to "guess"..
My Photobucket >>
