newbe - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 2nd, 05, 06:54 PM Thread Starter
newbe
just pickup a 67 coupe looking for comments
looking at putting in a 540 big block or a 434 small block it is a auto
lsatoo is offline
post #2 of 6 (permalink) Old Dec 2nd, 05, 08:09 PM
Christopher
Send a message via AIM to ctrghtous
Re: newbe
Welcome to Team Camaro!
what you do with the car in the build all depends on what your plans for the car are. Personally I'm partial to the sbc, but there is no replacement for cubic displacement.
If you tell us what you are looking for, what you have and what condition its in, and what budget you are looking at we can give you some suggestions.
Chris
68 camaro, sbc 385 (going together), holley 4150 750cfm, 4 spd, gm HEI, performer RPM intake
ctrghtous is offline
post #3 of 6 (permalink) Old Dec 2nd, 05, 09:31 PM Thread Starter
Re: newbe
the car is in good shape does have a 383 with dart heads, 3 inch exhaust
plan to drive the car , like to have lots of ponies chasis is stock has traction bars, front disc brakes
just don't know if having bbc with extra weight is bad.
lsatoo is offline
post #4 of 6 (permalink) Old Dec 3rd, 05, 09:31 AM
Re: newbe
Keep in mind that sbc. parts are everywhere. Going to bbc. you'll be starting all over.
68Camaro396/375 is offline
post #5 of 6 (permalink) Old Dec 3rd, 05, 09:33 AM
Talking Re: newbe
Converting to a big block is not cheap. Do a search and you will find all the "other" things you would need. Why swap out the 383 ? IMHO I would spend my money on upgrading the suspension and getting the 383 to hook up. Eric68 should have lots of pointers for you.
TJS69 is offline
post #6 of 6 (permalink) Old Dec 3rd, 05, 11:21 PM
Thumbs up Re: newbe
Agreed. I'd stick with the 383. They're notorious for putting down 450+ HP on pump gas. Pull the valve covers and check for some valvetrain goodies. 3" exhaust is a bit big for a 383, I personally run 2.5" true duals on my 81 Vette with a 383. It keeps enough backpressure around so that I don't lose too much torque at low RPM's. But as stated above, it all depends on what you want to do with the car. If you want to drag it, then there's no replacement for displacement. A 454 with aluminum heads doesn't weigh a whole lot more than a 383 with iron heads. Plus, we'll buy your SBC stuff off you along the way to help finance your project. Congrats on the purchase, and welcome to the forum. Prepare for lots of head turns when you're driving that thing.
jasonty is offline
