Intake Manifold Vacuum Fitting? - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 3rd, 05, 03:24 PM Thread Starter
I need some help determining which intake manifold vacuum fitting I need for my car. It is a 1968 RSSS BB AC AT (TH-400) Manual Steering and brakes. I know it needs to have at least one tube for the modulator valve from the transmission but not sure of the other stuff. Thanks!
Tim
tim68rsss is offline
post #2 of 7 (permalink) Old Dec 3rd, 05, 08:26 PM
Re: Intake Manifold Vacuum Fitting?
There may be an extra nipple for A/C/Heating vents needed.
post #3 of 7 (permalink) Old Dec 4th, 05, 05:54 AM
PCV valve in valve cover
Vacuum advance on distributer
Vacuum can for the light covers (RSSS)
Thats all I can think of right now... too early.
68 Camaro~LSx ~all motor
post #4 of 7 (permalink) Old Dec 5th, 05, 06:34 AM Thread Starter
Doesn't the PCV and vacuum advance connect to the carb? I trying to figure out which fitting I need that screws into the back of the intake manifold. I know it needs one tube for the transmission modulating valve but not sure of any other connections at that fitting.
post #5 of 7 (permalink) Old Dec 5th, 05, 02:29 PM
Sorry, I was confused on the question.
I run the PCV to back of carb and power brakes to manifold, but could go either way. Your not running power brakes so you could plug one of them.
post #6 of 7 (permalink) Old Dec 5th, 05, 06:18 PM Thread Starter
Okay, I think I have figured it out from the assembly manual. I need a fitting that will accommodate the transmission modulator valve, RS vacuum canister, and AC equipment. The manual list part # 3891527. Anyone have an idea where I may find this fitting?
post #7 of 7 (permalink) Old Dec 6th, 05, 04:27 AM
You might try www.hemmings.com and do a search.
Try an older recycle yard and most any GM product might have one.
People with 20- & 30-year bolt boxes would probably have one.
