Anyone know the weight of an iron BBC head? - Team Camaro Tech
post #1 of 12 (permalink) Old Dec 7th, 05, 12:08 PM Thread Starter
Question Anyone know the weight of an iron BBC head?
I'm trying to calculate weight differences on a couple setups I am looking at ans I need to kow the weight of a head such as a 049.
Not2LateForThis68 is offline
post #2 of 12 (permalink) Old Dec 7th, 05, 04:07 PM
Gary
Re: Anyone know the weight of an iron BBC head?
Approximately 67# for bare BB head. Oval and squares are the same weight. Thanks, Gary in N.Y.
P.S. BB G.M. aluminum, 29# also bare.
GOSFAST is offline
post #3 of 12 (permalink) Old Dec 7th, 05, 04:57 PM Thread Starter
Thank you!!!
post #4 of 12 (permalink) Old Dec 7th, 05, 05:26 PM
Gary
70 - 72 loaded unless you're talking Merlins. Those suckers are over 80 lbs apiece!
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
post #5 of 12 (permalink) Old Dec 7th, 05, 06:43 PM Thread Starter
OK, thanks for the input. Now I have a possibly stupid quiestion not concerning weight. Is there a differenct in a left and right head or are they interchangeable?
post #6 of 12 (permalink) Old Dec 7th, 05, 07:55 PM
Smile Re: Anyone know the weight of an iron BBC head?
No, not stupid... Only if you don't ask!!
They are the same!! Just like the SB heads are..
pdq67
post #7 of 12 (permalink) Old Dec 7th, 05, 08:55 PM
Chris
Cool Re: Anyone know the weight of an iron BBC head?
way heavy................
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Daily Driver)
1967 C10 Short-Wide 496BB/TH400/12-bolt (The Shop Truck)
2008 Harley Davidson Dyna Low Rider
Chris @
Motorhead62 is offline
post #8 of 12 (permalink) Old Dec 8th, 05, 06:12 AM Thread Starter
Thank you!!!
post #9 of 12 (permalink) Old Dec 8th, 05, 09:11 AM
Vintage 68's Avatar
Talking Re: Anyone know the weight of an iron BBC head?
Now I have a possibly stupid quiestion...
Like 'pdq' said - not stupid at all unless not asked
But, the real answer... is - there may be a difference in your heads, from 1968 on... They are physically the same (and interchangable) but may have a slight assembly difference.
Not a big thing but, they moved the Temp. Sensor to the LEFT (drivers) Side Head in a threaded hole between the front two exhaust ports on both BB and SB heads in '68.
Both heads should have a drilled & tapped hole, only the right (passenger) side head would have originally had a pipe plug in it. These plugs can be plenty hard to get out if they've been in for many years - so it's easier to just put it on the right/passenger side to begin with and use the open hole one on the left/drivers side to avoid having to deal with getting that dang plug out...
I have actually seen several engines that have had one head drilled/tapped and the other not - never investigated the casting dates or how this happened - don't think the factory put them out this way - but, I've been wrong about that before...
Just my .02 and trying to keep Paul on his toes...
John M
1968 Convertible
Some trucks
Vintage 68 is offline
post #10 of 12 (permalink) Old Dec 8th, 05, 02:22 PM
Whatever head weight you come up with....... multiply that number by 8 if you drop it on your foot. Thatll keep you on your toes...
Long Gone: 1984 Z28, 1989 RS
Current : 1967 Coupe w/350, 2010 2SS
My Photobucket >>
dragon0123 is offline
post #11 of 12 (permalink) Old Dec 8th, 05, 05:40 PM
Thumbs up Re: Anyone know the weight of an iron BBC head?
He, He!!
Thanks Vintage 68,
I need somebody to keep me on my toes!!
pdq67
post #12 of 12 (permalink) Old Dec 8th, 05, 07:04 PM
Chris
pdq67, I sent you a PM.
ck 2 is offline
