302 Power. - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 8th, 05, 07:12 PM Thread Starter
Thumbs up 302 Power.
I just got off the phone talking with Tony H. down in the SE part of the country.
Tony gave me some dyno numbers I thought I would share for him with his OK.
RPM Hp T
2000-----129----333
3000-----210----356
4000-----306----395
5000-----395----414
6000-----454----393
6500-----463----373
7000-----458----342
Tony said the motor is basically a stock, .030" over, 302 with, (I think I have this right?), a Crane Powermax F-278-2 solid lifter cam:
278/238/288/248, 114/109, .480"/.500" lift.
And Tony asked me if I wanted a copy of the dyno sheet b/c he said he's going to go get a copy of it and keep it just for.......
Sounds like one hard runnin' little motor to me!!
pdq67
post #2 of 8 (permalink) Old Dec 8th, 05, 08:43 PM
Re: 302 Power.
possible , the stock motors were pulling 425 at 6500 when dynoed
BadLatitude is offline
post #3 of 8 (permalink) Old Dec 9th, 05, 08:04 AM
Matt
Send a message via AIM to 70chevyz28 Send a message via MSN to 70chevyz28
Re: 302 Power.
sweet!!!..good ole chevy muscle.
1971 Chevrolet Camaro RS- 357 SB,built TH350,moser axles,eaton,richmond gears...PTFB/Detriot Speed suspension..etc
1966 Chevrolet C-10-95% orignal,292 I6..big torque
70chevyz28 is offline
post #4 of 8 (permalink) Old Dec 9th, 05, 01:15 PM
Re: 302 Power.
Those sound like great numbers to me, I'd be really interested in hearing the full specs
Guss_B is offline
post #5 of 8 (permalink) Old Dec 9th, 05, 05:59 PM Thread Starter
Smile Re: 302 Power.
Tony,
If you are peeking in on this, post the complete motor spec's.
If Tony doesn't chime in here in a bit, I will ask him all the details the next time we talk on the phone.
Tony is like me, he hunt and pecks so it is slow posting..
pdq67
post #6 of 8 (permalink) Old Dec 9th, 05, 06:07 PM
William
William's Avatar
Re: 302 Power.
We have been down this path before.
A stock as-installed 302 had about 325-335 hp. There was a dyno run performed in the '80s as part of a restoration feature in MCR I believe. They also tried it with the '140' cam and got about 20 more hp. Penskes' Traco T/A engines were just over 400 hp with Engle cams. Todays NHRA-legal stock class 302s are around 430 hp.
William is offline
post #7 of 8 (permalink) Old Dec 9th, 05, 07:21 PM
Tony
Re: 302 Power.
Paul I'll try to get the spec sheet tomorrow I'll give you a call.
'69 Frost Green Z/28
Tonyx33 is offline
post #8 of 8 (permalink) Old Dec 9th, 05, 08:23 PM
"Tri-Tip"
Gary L's Avatar
Re: 302 Power.
I don't build engines, but can you gain that much with what looks like a subtle cam change?
Gary L is offline
