Engine Pictures - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 8th, 05, 09:01 PM Thread Starter
Engine Pictures
I need to look at some LH side and top pictures of a '69 camaro 350 engine. The engine needs to be stock (original) with air cleaner removed. I need to clarify what and original kickdown cable and cable bracket looks like. Also with these pics i can see the correct linkage on a Q-jet carb.
Any pics or links to view engine pics would be greatly appreciated.
thanks.
kdka
kdka is offline
post #2 of 4 (permalink) Old Dec 9th, 05, 07:44 AM
click's Avatar
Re: Engine Pictures
Hope this helps, if you need something different just ask, I might have other pics in my system here.
This is the stock Qjet setup
click is offline
post #3 of 4 (permalink) Old Dec 10th, 05, 09:09 AM Thread Starter
Re: Engine Pictures
Thanks for pics. I still need a close-up pic of the kickdown cable bracket to see if the bracket is the original style like on my '69 camaro. I have been unable to find original style kickdown cable to attach to my bracket. Any help is greatly appreciated.
kdka is offline
post #4 of 4 (permalink) Old Dec 10th, 05, 09:53 AM
click's Avatar
Re: Engine Pictures
My bracket is a repro since it wasnt on the old Holley setup that was on the car when I bought it.. so for sure mine is not original bracket so I cant help you with that one.
click is offline
