Oil deflectors for BB - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 11th, 05, 04:49 PM Thread Starter
Does anyone make an oil deflector for BB heads. The oil isn't coming out of the rocker arms, like on a SB, but it actually leaks out the rear of the head. My heads are Edelbrock Performers. The biggest problem occurs on the driver side rear, when I am adjusting the valves, with the engine running. The oil pools in the rear of the head and overflows onto the header.
1968 RS convertible, 427, T-56, 3.73 12 bolt posi.
rickmack is offline
post #2 of 6 (permalink) Old Dec 11th, 05, 06:07 PM
Re: Oil deflectors for BB
Use tin foil on the rockers its cheap and works good. Just form it to fit over the push rod side.
Rogers Performance is offline
post #3 of 6 (permalink) Old Dec 11th, 05, 06:16 PM
Bob
Cut the top off of a cheap chrome tall valve cover and bolt it on for valve adjustments.
"The oil isn't coming out of the rocker arms, like on a SB, but it actually leaks out the rear of the head."
The oil should come out of the rockers unless they are rollers which are a little different. My flat tappet small and big blocks all shoot oil out of the rockers without deflector clips at any rpm above idle.
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
post #4 of 6 (permalink) Old Dec 11th, 05, 06:37 PM Thread Starter
Yep, they are Comp Cams roller rockers. Yea, I might just cut some old valve covers.
rickmack is offline
post #5 of 6 (permalink) Old Dec 11th, 05, 08:10 PM
DjD
DjD's Avatar
Do them cold and avoid the mess all together!! How have you been Rick? it's been a while! If gas prices stay down for a while you'll have to go cruising with us this spring...
...Dennis
DjD is offline
post #6 of 6 (permalink) Old Dec 13th, 05, 11:29 AM Thread Starter
Yes, it has been a while. I'll check out the website and plan to visit at some point.
For some reason, I have had better luck adjusting my valves when the engine is running. They are done now, it was just messy.
Anyway, see you.
rickmack is offline
