fuel system setup? - Team Camaro Tech
post #1 of 1 (permalink) Old Dec 13th, 05, 11:51 AM Thread Starter
fuel system setup?
I'm wondering if anyone has any recommendations for fuel system setup for a 383(320whp) with a quadrajet. Specifically from the gas tank to the carb.
I've got a new carb from SMI (which is great)and now know I have too much fuel pressure. This is in a 69 camaro, that I'm trying to prep for light autocrossing and track days.
I'm wondering if the stock fuel tank, lines, setup are up to the task.
The mechanical fuel pump I have now is a street holley unit that I have to add a regulator to reduce the fuel pressure. Should I add the regulator or would a stock replacement fuel pump be enough.
Would it be better to have a tank with baffles(for cornering?) and a electric fuel pump at the tank then regulator to carb?
any info would be appreciated!!
thanks,
chris
cakneller is offline
