Engine Frame Bracket - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 13th, 05, 01:31 PM Thread Starter
I know this has been beat to death before, but I still have a question. I did a search on engine mounts and frame brackets. I have something that just does't fit. I have a 67 Camaro Convertible big block car. The frame brackets
measure (D) 2.800" tall over all, (P) 2.560" tall over all.
(D) 2.25" to the center line of hole, (P) 2.00" to Center line of hole......These brackets are 2" wide. What brackets do I have here and what is the correct motor mount for them? When I get a motor mount that fits the 2" wide brackets they are wrong in heighth. When I get mounts the right height they are not the right width. Appreciate
and information.
Larry
Mooreboys is offline
post #2 of 3 (permalink) Old Dec 13th, 05, 05:02 PM
Re: Engine Frame Bracket
The 2.250 measurment tells me you got bbc mounts. As for the towers, I cant help you there but bet the TC crew can... Just what are the numbers on these towers?
TC # 349
zdld17 is offline
post #3 of 3 (permalink) Old Dec 13th, 05, 06:03 PM
"Tri-Tip"
Gary L's Avatar
This should answer your question on part numbers.
http://www.pozziracing.com/camaro_engine.htm
Gary L is offline
