Need photos of fuel line routing on SB. - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 13th, 05, 08:47 PM Thread Starter
I'm going from a 600 Holly to a 670 Street Avenger. With the alternator on the rt side, I don't have a lot of room for the fuel line and filter, and to make the bend from the front of the engine to the carb. I bought a chrome daul feed line to put on the carb, but with that installed, the nipple on the dual feed line is too far foward. I'm not into looks at this time. I just want it running with the fuel lines as far away from the heat as poss. I'd like to see some photos of how you all ran your lines. Thanks, Phil
PinMd is offline
post #2 of 3 (permalink) Old Dec 13th, 05, 09:18 PM
Re: Need photos of fuel line routing on SB.
I used a repro 69 Z28 fuel line kit - Performer RPM and a 670 Street Avenger (now run a 650 DP). It fits perfectly - all steel lines.
BPOS is offline
post #3 of 3 (permalink) Old Dec 14th, 05, 12:55 AM
Before moving to a full steel brainded line between the fuel bowls (so I can swap jets on one without undoing the other), I had a hard line carb to steel brainded plumbing to the pump right between the alternator and water pump. Using a one-wire alternator makes it a lot easier.
SoCalFirstGen is offline
