motor mount question... - Team Camaro Tech
post #1 of 14 (permalink) Old Dec 14th, 05, 05:56 PM Thread Starter
I did search for this but could not find anything....
Should there be a gap between the motor mount and the pearch that the mount attaches to? I have like a good 1/4 to 3/8" gap or space between the width of the pearch and the width of the mount...
Liveinaz is offline
post #2 of 14 (permalink) Old Dec 14th, 05, 06:19 PM
Re: motor mount question...
I have the same gap on the passenger side of my 68, but I cant remember if it was on the drivers side too. Hangs off the rear of the subframe?
SoCalFirstGen is offline
post #3 of 14 (permalink) Old Dec 14th, 05, 06:28 PM Thread Starter
I am talking about a gap on the side of the mount between the pearch and the mount...here is a pic...
Liveinaz is offline
post #4 of 14 (permalink) Old Dec 14th, 05, 06:28 PM
The frame brackets do both hang off the back of the sub, but the engine bracket and frame stand should fit together tightly. There are 2 different types, 327-307are different from 350-302, see David's site for the details: http://www.pozziracing.com/camaro_engine.htm
hey, a pic appeared!!! looks like you have 350 engine mounts on 327 frame stands
post #5 of 14 (permalink) Old Dec 14th, 05, 07:00 PM Thread Starter
Jim,
do you think it is the stand that is wrong? Will the motor mounts from a 327 bolt to the 350 motor? I guess that if I had the wrong motor mounts say from a 327 they would be too small for the 350 stand...
are you pretty sure it is the stand that is wrong?
Liveinaz is offline
post #6 of 14 (permalink) Old Dec 15th, 05, 06:29 PM
JohnZ's Avatar
283's through 400's (plus big-blocks) all have exactly the same mount-to-block bolt pattern, but you have to match the other side of the mount to the frame stands, as they differ.
JohnZ
CRG
JohnZ is offline
post #7 of 14 (permalink) Old Dec 15th, 05, 06:57 PM
Robert
I'll add to what John said with you will not likely get the correct mounts from your local parts store. Identify the frame stands and then purchase the corresponding mounts from a major repro supplier like Rick's (or any of the others). I had the same problem (yet worse) on the '69 and after getting the "right stuff" there was no gap and the engine sat 1/2" higher than before, which was a good thing.
Robert
TC member #18
rojo is offline
post #8 of 14 (permalink) Old Dec 15th, 05, 09:57 PM
I just went through this problem on my 69. After a long talk and much measuring with tech at Ricks First Gen. The
327 or low perf type frame bracket is their EB-4. The correct motor mount for this bracket is one that measures 1 11/16" from back to center line of the hole and is 2" in the saddle (between the mounts ears. I am using Moroso
steel mounts with Part #62500. Maybe this might help.
Larry
Mooreboys is offline
post #9 of 14 (permalink) Old Dec 15th, 05, 11:13 PM
Jody
camcojb's Avatar
You have 302/350 frame stands and 327/307 motor mounts. The low performance small blocks had a wider perch than the performance ones.
You need mounts for a 302/350 or frame stands for a 307/327.
Jody
camcojb is offline
post #10 of 14 (permalink) Old Dec 16th, 05, 07:38 AM Thread Starter
Jody
Jody,
Is there one or the other that will be better for me to get more clearance around the header/steering gear box?
Liveinaz is offline
post #11 of 14 (permalink) Old Dec 16th, 05, 08:15 AM
Jody
camcojb's Avatar
Originally Posted by Liveinaz
Jody,
Good question. I'm not sure if there's any height or engine placement differences between the two; just the width of the perch which makes a situation like yours not good, too loose.
Jody
camcojb is offline
post #12 of 14 (permalink) Old Dec 16th, 05, 03:15 PM
Talking Re: motor mount question...
Looks fairly typical to me. The tab will deflect when you tighten down the bolt. If it bothers you slip a washer in. Probably one of those parts now made in China.
f370vette is offline
post #13 of 14 (permalink) Old Dec 16th, 05, 03:52 PM
Robert
Jody,
Yes, with the correct mounts my engine sat 1/2" higher which added to the header clearence around the steering box as well as underneath. But I'll say again I was unable to get the "correct" mounts from a local parts store. The ones they showed me looked way different from the ones I got from Ricks.
Robert
TC member #18
rojo is offline
post #14 of 14 (permalink) Old Dec 16th, 05, 07:11 PM
Smile Re: motor mount question...
I would use a stock 350 rubber mount that first came out in '67.
It is the little one over on the left in David's pic's. It isn't locked together so it will break real easy!!!
I broke both mine shortly after I got my car and all I did was take them both off and drill a 3/8" hole through both halves and countersink one side and then I used a 3/8" countersunk head machine bolt and a nut and lockwasher and bolted BOTH halves back together!! Worked great AND it did away with my homemade chain/turnbuckle torque limiter....
I got my motor mount recall letter from GM about then and after the way the Dealer jerked me around, I didn't take my car back to replace them with the safety-loc ones b/c mine worked great from there on!!
They were still on my car after going through my 350, my 409 "W" motor and finally my old junk301 when I traded it off..
pdq67
