New BB - How Much Coolant? - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 16th, 05, 02:57 PM Thread Starter
Just installed my rebuilt BB with a 4-core radiator. How much coolant should the whole system hold? I have put about 6 1/2 gallons of antifreeze/water (50/50 mix) into the system. Have completed the cam break-in period of running the motor at 2000 rpms for 30 minutes and ran it about another 15 minutes to find and seal exhaust leaks. The fluid is about 1" below the top of the radiator. Is this about right? Thanks!
Tim
tim68rsss is offline
post #2 of 6 (permalink) Old Dec 16th, 05, 03:17 PM Thread Starter
Re: New BB - How Much Coolant?
Found the answer in my owners manual. Didn't think about that reference.
V8 396 - 23.5 quarts of coolant
add 2 more quarts if AC car
I'm in the ball park!
post #3 of 6 (permalink) Old Dec 16th, 05, 03:45 PM
[quote=tim68rsss]Found the answer in my owners manual. Didn't think about that reference.
Cool ! You still have an Owner's Manual? One inch below is good. Check it again when cold and add. Do another heat cycle and check again the following day for level. Should be 1 inch below.
Everett#2390 is online now
post #4 of 6 (permalink) Old Dec 16th, 05, 03:46 PM Thread Starter
Thanks!
post #5 of 6 (permalink) Old Dec 16th, 05, 04:00 PM
Tim, the rad should be marked, on the back of the pass side tank, "full hot" and "full cold" Full hot is 1" or so below the neck. Full cold is 3 or so inches below that. If you overfill, it will puke and make a mess.
post #6 of 6 (permalink) Old Dec 16th, 05, 07:13 PM
Smile Re: New BB - How Much Coolant?
NO!!
Fill it until it is FULL AND stops burping and the T-Stat opens up!!
pdq67
