carb question - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 18th, 05, 10:08 AM Thread Starter
carb question
i have a 67 rs with a 327 and it has a 4777-2 holley(650 dp) and not sure what kind of cam but a very lopey idle to it, i just recently purchased the car and was wondering if the carb that is on it is a good match or if someone had a better recommendation, the car runs very rich and ive got a few other dilemmas that have come up but was wondering about the carb, any advice would be greatly appreciated
ronRS is offline
post #2 of 5 (permalink) Old Dec 18th, 05, 10:15 AM
Harry
dawg's Avatar
Re: carb question
carb is a little on the big side BUT
depending on the cam it could be just right
I would check the power valve on the metering plate.
a blown PV willl give you a overly rich mixture
434 stroker
US Navy retired
dawg is offline
post #3 of 5 (permalink) Old Dec 18th, 05, 10:24 AM Thread Starter
Re: carb question
thanks for reply, when the car is sitting in my garage it smells like straight gas and i can even smell it downstairs when i first walk in, not sure what that is about and when im idling at a stop sign or red light i get alot of exhaust and now the car is wanting to idle down low enough to stall when i come to a stop, so ive got some issues to work out and not sure what could be causing all this but looks like im going to have to send it to a mechanic because im just learning in the mechainc department and was trying to get some suggestions before i take it in thanks again for the reply
ronRS is offline
post #4 of 5 (permalink) Old Dec 18th, 05, 11:16 AM
Eric
Re: carb question
I am working this out right now...650 speed demon, I leaned out the idle and used a vacume gague, 9" steady at 950 rpm, any lower and it just will not run, Did you try to adjust the idle screws at all?
EC's 327 is offline
post #5 of 5 (permalink) Old Dec 20th, 05, 12:25 AM
Harley D
HarleyD67's Avatar
Re: carb question
I would start with checking the fuel float level, and fuel pressure. "If it's not a stock pump." Then adjust the idle mixture. You may also want to look at changing the metering jets down a few sizes. This will make the carb " act " a little smaller without the expense of a new carb.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
