Big block heads - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 18th, 05, 11:19 AM Thread Starter
Big block heads
I'm looking for a good set of heads for my blown 502 project. I need around 188-120cc chambers for the desired 8.6:1 compression.
I was leaning towards AFRs, but for $1000 less you can buy 24-degree rectangular port Edelbrock heads:
http://store.summitracing.com/defaul...=egnsearch.asp
Unforunately I can't find flow numbers to compare to the AFRs. Does anyone know if Edelbrock has published numbers, or if anyone else has flow tested them?
I would imagine the AFRs will outflow them at high lift, but I'm more concerned about the .350-.500 range anyway, so if they were comparable at that lift and I could save a grand and get them tomorrow, it'd be compelling.
Thanks,
1969 RS/SS 396 Camaro [MPFI Supercharged 502 Under Construction]
2007 427 Z06 Corvette
1969 Pontiac 2+2 427/390
2003 CL600 BiTurbo Renntech Stage III (635hp - [email protected]) [Sold!]
2006 Range Rover Eaton Supercharged
davepl is offline
post #2 of 3 (permalink) Old Dec 18th, 05, 07:29 PM
Thumbs up Re: Big block heads
If bucks are tight, you might consider the new cheap BB Aluminum heads that Powerhouse is selling right now for like $789/pr. BARE! AND set them up the way you want them.
They should be great cheap heads, imho..
pdq67
post #3 of 3 (permalink) Old Dec 21st, 05, 04:25 AM
Re: Big block heads
I remeber when I was shopping around for heads I saved $1000 on Dart pro 1 heads vs. the Afrs and the flow numbers where very similiar.
Made 700hp in a 540 for my boat! (pump gas motor)
fonz69 is offline
