'69 Clutch Question - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 18th, 05, 04:26 PM Thread Starter
'69 Clutch Question
I've got a '69 350 4 speed that is missing the clutch return spring. I bought a spring, but had problems with the installation. I see where it attaches to the clutch fork but don't see where to attach the other end. Any help anyone can offer would be appreciated.
Thanks,
Bob
bobc is offline
post #2 of 5 (permalink) Old Dec 18th, 05, 06:11 PM
JohnZ's Avatar
Re: '69 Clutch Question
There's a small hole near the rear edge of the frame-side motormount stand for the return spring; shown in the A.I.M. in UPC 7, Sheet C3.
JohnZ
CRG
JohnZ is offline
post #3 of 5 (permalink) Old Dec 19th, 05, 02:06 PM
The stock setup used a return spring and a return spring extension rod. The extension is made from the same gauge wire as the spring with a hook on one end and a loop on the other. You should be able to get both from a resto supplier or maybe even GM.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #4 of 5 (permalink) Old Dec 22nd, 05, 08:05 PM Thread Starter
Thanks, JohnZ and 12Run for your replies. I neglected to mention I have headers and it looks like the headers would interfere with the spring if I try to connect it to the motor mount. No hole appears to be in the motor mount.
bobc is offline
post #5 of 5 (permalink) Old Dec 23rd, 05, 06:58 AM
Because of the headers, I made a heavy "L" tab bracket and mounted it in an area just below and forward of the steering box. Use a long neck heavy spring to the fork hole. I also have a shorter "anti rattle " spring from the fork hole to the Z bar hole,, just to keep these from falling out , should the clutch stick to floor in hi rev situation? With stock Bellville type pressure plates, this used to be an issue but not now, I use the Centerforce design. On old habit.
TC # 349
zdld17 is offline
