350 Engine Specs needed - Team Camaro Tech
post #1 of 10 (permalink) Old Dec 19th, 05, 09:23 AM Thread Starter
Unhappy 350 Engine Specs needed
I need to know some specs for the 1969 350/300 horse engine...
Crankshaft: does it have a one piece or 2 piece end piece? Large or small journal type? (Pls give both specs)
Camshaft: what is the type used on this engine?
Can I go with roller rockers & still have no clearance problems with the stock aluminum LT1 valve covers?
Pistons: can I go with domed or must they be flat-top?
Any help appreciated! And Merry Christmas!
NOTE: I have the original 350 4-bolt main block & I am rebuilding it for my car, but it is a bare block....
Salerno
1969 SS Garnet Red Convertible
Salerno is offline
post #2 of 10 (permalink) Old Dec 19th, 05, 10:06 AM
Wes
Re: 350 Engine Specs needed
1) Two-piece rear main seal
2) Large journal
3) Very small cam,..something like .410 lift. You'll want to replace it with something bigger.
4) I don't know of any roller rockers that will fit under the alum. finned valve covers, but the Comp Cams Roller Tips fit fine. Good pieces,..I recommend them.
5) There are one thousand choices for pistons. Originally, your L-48 (SS-350) came with flat-tops with small valve reliefs. With the 186 heads, they made 10.25 compression. If you go a larger cam, you can up the compression a bit, but not much with iron heads.
Good luck!
Straight-line-69 is offline
post #3 of 10 (permalink) Old Dec 19th, 05, 12:57 PM
Roller rockers will not fit under LT-1 and stick with the flat tops.The 11-1 piston will give you severe detonation even with a big duration cam. I a 70 Z it is not enjoyable to drive with only 4 degrees advance and a carb jetted rich.I built an engine for a customer in a 70 z and used forged flat tops with the 186 castings[64cc] and it was much more user freindly........www.hardcoreparts.ca
pro1 is offline
post #4 of 10 (permalink) Old Dec 19th, 05, 04:33 PM
Large journal type - Mains 2.4479-2.4488 Rods 2.099-2.100 (these are factory specs)
The 69' used a .390 lift in. & .410 ex. w/ 112 Lobe Center (not positive it may have been 114)
I have done this before but it required either spacers or gaskets. FeliPro FPP-1604 (Thickness (in): 0.313) work very good for this. I haven't checked actual clearance but it cleared a .500 lift cam with Harland Sharp rockers.
I'm not sure of what your building or your goal is. Are you trying to copy a 1969 350/300 horse engine or just want that power? 1 hp per ci is easily obtainable and street-able these days. What heads are you using? This and other factors such as block deck height are required to make this assessment.
Same to you
TexasPerfProd is offline
post #5 of 10 (permalink) Old Dec 19th, 05, 05:56 PM
Thumbs up Re: 350 Engine Specs needed
Ah, yes, the great little old, -929 hy-cam!!
195/202, 112/108, .390"/.410" lifts.
It's a shame GM didn't stick, say a stock type Performer cam in the old 295hp and 300hp/350 motors instead of the -929 for just that little bit more power increase due to no other reason than it's size increase over the 300hp/327 motor that ran the same cam....
pdq67
post #6 of 10 (permalink) Old Dec 20th, 05, 12:01 PM Thread Starter
Thanks to all of you very much, and Merry Christmas!
Salerno is offline
post #7 of 10 (permalink) Old Dec 20th, 05, 12:07 PM Thread Starter
yes, I'm trying to copy the 350 cid/300 hp engine. I have the ultra rare 388
4-bolt main block (original) and the original 186 heads; all are date matched.
The heads are getting stainless valves, bronze guides job; wondered about going to roller rockers... The block has never been bored & the machinist says a .030 job will clean everything up just fine. I'm not a 80+ mph driver but want that horsepower there...
Salerno is offline
post #8 of 10 (permalink) Old Dec 20th, 05, 06:54 PM
I am using comp magnum roller tips on my stock finned covers but took some of the drippers off. Some of the vent baffles may have to be squeazed a little sometime but not always. Stay narrow and it will work.
TC # 349
zdld17 is offline
post #9 of 10 (permalink) Old Dec 20th, 05, 07:01 PM
what do u mean ultra rare 388 block....i just dont know what ur talking bout ty merry christmas
longhorn is offline
post #10 of 10 (permalink) Old Dec 20th, 05, 07:04 PM
buy the way like the name sounds like a mobster name
longhorn is offline
