Low vacuum - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 19th, 05, 11:31 AM Thread Starter
Low vacuum
I just had someone help me adjust my timing and carb on my Z/28 and we noticed that it only has 5" of vacuum at idle. This is low. I adjusted the valves a couple of days later but that didn't change the vacuum. What would be the likely culprit of this? Timing, compression, etc.?
Also, since I installed a smog system, removing the passenger side rocker arm cover is a pain. I had to remove the smog tube from the manifold just to remove it. There has to be a better way. Any ideas?
Dave, member number 7704
2000 Dodge Viper GTS
drdave69 is offline
post #2 of 9 (permalink) Old Dec 19th, 05, 01:09 PM
Re: Low vacuum
Assuming you are using the original style camshaft the 302 cam has excessive duration,hence the lack of torque and low vacuum.There are far better solid cams on the market today that will help your situation www.hardcoreparts.ca
pro1 is offline
post #3 of 9 (permalink) Old Dec 19th, 05, 03:03 PM
Re: Low vacuum
With OE camshaft, should be around 8-9 in/Hg. vacuum.
I'd probably throw in alittle more initial timing to bring up vacuum, but not enough it would kick back against the starter when hot.
If the kickback happens, too small of battery cables, min of 1 AWG, plus too small of reserve battery won't help starter spin fast either. And starter condition is a factor also.
post #4 of 9 (permalink) Old Dec 19th, 05, 04:26 PM Thread Starter
Re: Low vacuum
We set the initial timing at 12 degrees (this is on the OE camshaft and not planning to replace it). It starts and runs fine even after getting to operating temp. Doesn't knock upon accelerating that I can hear.
drdave69 is offline
post #5 of 9 (permalink) Old Dec 20th, 05, 09:19 AM
Re: Low vacuum
Vacuum leak somewhere?
Will it idle down further, say to 700-750? If it does, good indication of no vacuum leaks.
I suggested 8-9 jn./Hg of vacuum at idle because JohnZ offered this value sometime in the past.
I believe idle rpm is set around 900 rpm. If one revs up to say 1500, vacuum should come up. Throw a rag over the carb air horn and listen to what happens. If it dies,good setting, If ti revs up, vacuum leak or too lean.
post #6 of 9 (permalink) Old Dec 20th, 05, 09:20 AM
Re: Low vacuum
Double post
post #7 of 9 (permalink) Old Dec 20th, 05, 05:14 PM Thread Starter
Re: Low vacuum
It idles around 900-1000. The next time I have it running I'll try the rag over carb trick.
It has always had a very strong smelling exhaust but it seems unbearable now. I have 5 gallons of 110 racing fuel mixed with the 93 unleaded. The exhaust gases burn my eyes and the smell stays in my clothes/hair if I stand around the garage with it running. Could this be a too rich condition?
drdave69 is offline
post #8 of 9 (permalink) Old Dec 20th, 05, 08:48 PM
Re: Low vacuum
Yes. Spark plugs would be dry black if idled too long. You might try to open secondaries just hair so the primaries could close alittle more to allow more effect of mixture screws. Use the stop screw on pass side of throttle plate to open secondaries.
A slotted setscrew is only available from the bottom, meaning carb removal. Screw screw out and screw with slot on top from the top for easier adjustment.
If secondaries opened too far, curb idle won't be able to decrease to 900-1000 rpm. Trial and error setting.
post #9 of 9 (permalink) Old Dec 21st, 05, 12:45 PM
Re: Low vacuum
Valve issues usually cause the vacuum needle to pulsate.
dnult is offline
