Speed demon carb - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 20th, 05, 08:03 PM Thread Starter
Question Speed demon carb
I am running a speed demon 750 vac sec carb on my 454 has anybody had any problems with the float sticking? I was trying to run it the other day and kept getting gas pumping out of the rear vent tube while it was cranking.
RNGZ is offline
post #2 of 2 (permalink) Old Dec 20th, 05, 09:45 PM
Re: Speed demon carb
YOU EITHER HAVE DIRT UNDER NEEDLE/SEAT,FLOAT SET TO HIGH,BENT FLOAT,OR TOO MUCH FUEL PRESSURE IF IT IS AN AFTERMARKET PUMP. YOU MIGHT WANT TO CHECK THE PRESSURE AND ADD A REGULATER www.hardcoreparts .ca
pro1 is offline
