Checked timing and adjusted.... - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 22nd, 05, 11:57 AM Thread Starter
robert
rolling-robert's Avatar
Bought a great timing light today, it has a digital advance and shows the rpm, and it has a steel clamp instead of plastic.
My old ****ty timing light had a plastic clamp that melted away after hugging the header.
Anyway i first found the correct TDC and then i plugged the vacuum advance and set timing at 10 degrees BTDC, THEN i revved the engine and found the timing come in at 1300-1500 rpm at 36 degrees BTDC.
it didnt like idling at 10 degrees BTDC, ut hooking up the vacuum advance brought it to 25 degrees BTDC, it idles fine.
--Isnt 25 degrees BTDC too much while idling?
--I think going full advance at 1500rpm is too soon because if you rev it quick in neutral i hear some detonation.
What do you think about this?
BTW: its the 87 camaro in the SIG.
thank you
*RR*
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #2 of 5 (permalink) Old Dec 22nd, 05, 12:12 PM
Re: Checked timing and adjusted....
36 @ 1500 is way too fast. Check your advance wieghts and springs, maybe a spring came off?
25 at idle is not too much, may not even be enough, but I wouldn't mess with it before you get the mechanical advance under control. If it's pinging reving under no load, it'll ping bad when you try to drive it.
post #3 of 5 (permalink) Old Dec 22nd, 05, 12:16 PM
"Tri-Tip"
Gary L's Avatar
error.
Gary L is offline
post #4 of 5 (permalink) Old Dec 22nd, 05, 05:37 PM
Sounds like your vacuum advance is fine. 25* at idle is about right. As soon as you load the motor it should fall back closer to 10*. Check the busings on your advance weights and try a stiffer spring on one of the weights. Mechanical shouldn't be all in until somewhere between 2000 and 2500.
dnult is offline
post #5 of 5 (permalink) Old Dec 22nd, 05, 11:27 PM Thread Starter
robert
thats what i thought!
the whole ignition is brand, spanking, shiny new, so it isnt worn out out or something, ill take a stiffer spring.
cya!
Z28 1984
