Can't keep the belts on my 396 - Team Camaro Tech
post #1 of 16 (permalink) Old Dec 25th, 05, 06:38 PM Thread Starter
It seems everytime I rev the engine above 5500 the alternator belt comes off. This has happened 3 times over the past two months. I have replaced the belt but still no luck in keeping it on. Yesterday my son took it out and this time both P/S belt and alt belt came off. I have checked the alignment and all looks well. The belts and pulley are standard v belt design. I am looking at going to the serpentine in hopes this annoyance will end. Any thoughts? I am looking at March right now but will take recommendations. I have a 396 with long water pump and a key way P/S pump no A/C.
Mister G is offline
post #2 of 16 (permalink) Old Dec 25th, 05, 06:47 PM
kris
Send a message via AIM to kristofer
Re: Can't keep the belts on my 396
"Top Cog" belts by dayton........
any other belt and i throw them...
1968 CamaroCorvette Bronze 396 TKO-
1978 Camaro Type LT 99% original
2005 FLSTFI 15th anniversary Fatboy Softail.
kristofer is offline
post #3 of 16 (permalink) Old Dec 25th, 05, 06:48 PM
kris
I meant to say...
"Top Cog" belts by dayco/gates........
I can give you part numbers if you like..
I have a 396 with ps, and alternator on drivers side....no ac
my alignment is not perfect, and the top cogs stay on........PERIOD
6000 rpms ALL day long
Advance Auto Parts
alternator number is 17580 Gold Label Top Cog 17/32" x 58" belt
Power steering is 37513 Drive Rite 29/64" x 37-.50" vbelt
these have been on for a whole season with no issues......
post #4 of 16 (permalink) Old Dec 25th, 05, 06:49 PM
Lee
I had the same problem with my 396 Chevelle with PS and AC. You have got to really look at the alignment. Even though it may look good, really look hard at it and adjust as necessary. The slightest little bit out of alignment will throw them off. I also had to keep them super tight, don't know if that is the right solution, but it worked for me. Once I got the aligment and tightness straight, I could rev the day lights out of it with no issues.
69Project is offline
post #5 of 16 (permalink) Old Dec 25th, 05, 07:19 PM
Also Consider Deep Groove Pulleys Like On All 375/425 Hi Po Motors
pro1 is offline
post #6 of 16 (permalink) Old Dec 25th, 05, 08:54 PM
Just happened to me,first time out with a 502 in my Chevelle and off went the Alt. belt, I would like that part #. Thanks
BudW is offline
post #7 of 16 (permalink) Old Dec 25th, 05, 08:56 PM
kris
these are the numbers that worked for my car...power steering AND alternator both on driver side..NO AC.
Advance Auto Parts
as far as the deep groove goes...dont know, but i am sure summit or jegs has the hookup.
post #8 of 16 (permalink) Old Dec 25th, 05, 09:04 PM
Farm Boy's Avatar
I had the same problem with a 61 Vette. I was throwing fan belts and eating water pump bearings. One day I was revving the engine with the hood open and noticed the fan was wobbling. The fan clutch was bad. It would only wobble at high speed. I replaced the fan clutch and never threw another belt.
Farm Boy is offline
post #9 of 16 (permalink) Old Dec 25th, 05, 11:12 PM Thread Starter
Thanks for the feedback. I may get some of those belts before I try the conversion. My alt and p/s are on opposite sides.
Hope you guys all had a great Christmas. My wife just gave me $300 to buy a gift for the Camaro as well as a prime rib dinner. Sweet!
Mister G is offline
post #10 of 16 (permalink) Old Dec 26th, 05, 07:49 AM
Smile Re: Can't keep the belts on my 396
Years ago my alt. bearing was beginning to go south when I started throwing it's belt.
pdq67
post #11 of 16 (permalink) Old Dec 26th, 05, 08:22 AM
Jeff
My 350 used to through the belt at 5500 evertime, until I bought a Moroso 5in, deep groove alternator pully. Slows everything down.
Jeff
- 400 Dart Little"M", SRP 10.2:1, 4340 Scat rotating Assy, Solid Roller, AFR 210 Eliminators, Jesel shaft rockers,Super vic, Prosystems 847CFM, Tko600, 12 bolt 4:10 Eaton posi W/ Strange Hy-Tuf race axles and eliminators.
Best E.T. (11.96 @ 118.06) N/A
Classic Copper 4 Spd
jcdubs is offline
post #12 of 16 (permalink) Old Dec 26th, 05, 08:32 AM
I had the same problem when I was racing my 68 Camaro back in the day. Never did find a cure but when your up around 7 grand what can you say? I just put it back on and kept racing and I did have the deep groove pulleys...
COPO9737 is offline
post #13 of 16 (permalink) Old Dec 26th, 05, 08:41 AM
I seem to rember using deep groove and double belt pulleys when were kids in the late 70's???.. sound right??....
PLT-1 is offline
post #14 of 16 (permalink) Old Dec 26th, 05, 11:30 AM
Nick
"Top Cog" belts by dayco is the only way to go !!!My small block i take up to 7500 rpm with no problem!!!! before with any other belt 5000 was my limit.your LPS will have them in stock.Happy Holidays Nick
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #15 of 16 (permalink) Old Dec 26th, 05, 11:59 AM
Harry
dawg's Avatar
screw all the temp fixes .
I used to throw my belts all the time until I did this
link to the site here:http://www.blackmountainprecision.com/
434 stroker
US Navy retired
dawg is online now
