carrier bearing question on chevy 10 bolt 8 1/2 in. - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 25th, 05, 06:50 PM Thread Starter
I know this isn't a Camaro question but maybe one of you rear end gurus can help me out. I've got a 95 Suburban with a 10 bolt, 8 1/2 in. rear end with 373. When I change out the carrier bearings do I have to reset the preload. I appreciate any input. Thanks
donscamaro is offline
post #2 of 3 (permalink) Old Dec 25th, 05, 06:54 PM Thread Starter
Re: carrier bearing question on chevy 10 bolt 8 1/2 in.
Sorry, I screwed up and posted this in the wrong section. Should I repost it in the correct section or should I wait for it to be moved for me.
post #3 of 3 (permalink) Old Dec 25th, 05, 07:22 PM
Shouldnt Have To Check The Pinion But Make Sure You Put Allthe Proper Side Shims In The Same Order.sometimes You Get Lucky
pro1 is offline
